Are XJ axle parts interchangable with ZJ? - JeepForum.com
post #1 of 5 Old 06-30-2010, 11:28 AM Thread Starter
WilsonZone
1978 CJ5
I needed a car for my daughter to drive so she'd quit driving my JK. I found and bought a 1994 Grand Cherokee Limited with full-time 4WD that needed work. The seller told me that the driver's side CV axle shaft needed to be replaced. After looking underneath I noticed the boot on both sides were torn so I talked them down and took it home.
Before I worked on the Jeep you could hear loud popping noises and the front end felt like it was catching on something. After replacing the axle shafts the noise is still there. I'm now thinking that I need a new diff.
Yesterday I was at the local Pull-A-Part looking for u-joint axle shafts for this ZJ but they only had one 4X4 ZJ and it didn't have what I needed. They had about 15-20 XJ 4X4s there. If I could find a XJ with the same axle ratio as what I have could I pull the diff from an XJ and put it in my ZJ?
TIA
WilsonZone is offline
post #2 of 5 Old 06-30-2010, 11:51 AM
ajmorell
ajmorell's Avatar
If the gear ratios match just snag the entire axle assembly and swap it over. Much easier than swapping the internals of the differential. To answer your original question though, an XJ axle should bolt right into a ZJ.
ajmorell is offline
post #3 of 5 Old 06-30-2010, 11:52 AM
ajmorell
ajmorell's Avatar
If the ZJ has full-time 4wd then it's possible the viscous coupler in the t-case is shot too which would cause the binding you feel.
ajmorell is offline
post #4 of 5 Old 06-30-2010, 03:09 PM Thread Starter
WilsonZone
1978 CJ5
Thanks for your reply.
I only feel the binding in the front of the Jeep. Would a bad viscous coupler still do this?
So much for quickly getting a Jeep running for my daughter to drive.
Edit: Nevermind. Pulled the diff cover off and my pinion gear is busted. Looks like I'm replacing the axle.
post #5 of 5 Old 10-21-2010, 11:13 PM Thread Starter
WilsonZone
1978 CJ5
Well, I bought a front axle from the salvage yard and did the swap. Unfortunately after my daughter had been driving it around for a while the ZJ broke down on the side of the highway. I went to retrieve it and the front pinion gear is shot again. I'm guessing the VC is bad and caused the pinion gear damage.
After I brought it home I pulled the drive shaft, ring, pinion and axle shafts out. I had two old axle shafts that I cut down so the bearings didn't separate. I'll be doing a NP242 swap within a month or two.
We have a slanted driveway and about 30 minutes after parking the ZJ I found it had rolled into the street. I noticed that the Jeep very slowly rolls back; you have to really watch it close to notice it. I've never seen this before, would having a bad VC cause this? Or is it because I have no front driveshaft?
axle , cherokee , differential , pinion , ring
Should I look to buy axle assemblies or only replace certain parts? Goose797 Engines & Drivetrain 0 02-07-2010 11:32 AM
Are JD2 and Pro Tools dies interchangable? 72cj5er Fabrication Shop 2 03-04-2007 02:41 PM
Axle conversion - Need parts. Got em? sjlplat General Jeep & Off-Road Equipment 0 05-04-2005 06:56 PM
Are rims interchangable? cherokeeIVAN Tires & Wheels 5 03-06-2002 07:04 PM
Are rims interchangable? cherokeeIVAN Tires & Wheels 1 03-06-2002 06:47 PM
