Wrangler wont start. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Wrangler wont start.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Engo winch sale-- Best deal you will find. and FREE SHIPPI
Unread 09-18-2010, 05:52 PM   #1
AustinNaustiN
I parked the Jeep in my driveway and a week later was not able to start it.
The engine cranks and cranks but never starts. I took the fuel line off, turned the key on, and watched as the fuel pumped out for about 2 seconds and then stopped. If I spray some engine starter in the intake it will run for a second or two. Switched some relays around under the hood with the fuel pump relay as well.
Any ideas? Help is always appreciated.
My Jeep: [URL="http://www.jeepforum.com/forum/f22/trixie-tricked-out-jeep-1009381/"]Trixie the tricked out Jeep turnin' wheels on the cheap[/URL]
AustinNaustiN is offline   Reply With Quote
Unread 09-26-2010, 06:48 PM   #2
chainbrain2002
sounds like fuel pump. get a gauge and see if it holds pressure while cranking the engine over.
chainbrain2002 is offline   Reply With Quote
Unread 09-26-2010, 08:22 PM   #3
AustinNaustiN
Well when I took the hose off and cranked the engine it didn't pump any fuel other than the initial 2 seconds it pumped. I recently changed the fuel pump on another jeep so I know it's easy to do. Didn't really want to spend the money on a fuel pump though.
