would this work? - JeepForum.com
post #1 of 3 Old 06-12-2006, 07:22 PM Thread Starter
QElliott17
2010 JK Wrangler
would this work?
If I ordered this
http://www.jeepsareus.com/Merchant2/...Code=Wrangler1
would i be able to use these and just bolt them on?
I want to regear my dana 35 but i figured it would be better to just go ahead and replace both axles. I know this is expensive but my question is would these be all I need? They say complete kit.
-2010 Wrangler Unlimited Rubicon, Red
QElliott17 is offline
post #2 of 3 Old 06-13-2006, 11:43 AM
de6w6it
What it says down the bottom I think sums it up, if you bought that kit, and added the air pumps for the lockers, you have to supply:
wiring and switches for the pumps for the ARB's
hubs, spindles, and brakes from the D30 that is probably on your rig now
other than that, seems to me like it is actually a complete kit.
'66 Mustang/200/C4/ground up resto
'88 4 runner/SAS/22re/W56/duals/31's DD
Build:
de6w6it is offline
post #3 of 3 Old 06-13-2006, 03:45 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Those are factory air-lockers, not ARB's. The ARB uses 90 psi to lock, the rubi air-locker is around 5-7 psi. I'm sure you will need to get your hands on the factory air compressor and regulator for the rubi axles.
HTH
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
Will this work? samger2 Audio, CB & Ham Radios, GPS, & Electrical 12 03-22-2007 08:18 PM
Will this work? TQ_xvi Tires & Wheels 4 07-13-2005 01:38 PM
Will this work? Plink Engines & Drivetrain 1 06-25-2005 06:08 PM
how to work 4wd 94jpwrangler General Jeep & Off-Road Equipment 2 06-30-2004 11:33 PM
Will this work? Stock88YJ Engines & Drivetrain 2 06-29-2004 09:19 PM
