worn out main thrust bearing - JeepForum.com
post #1 of 4 Old 05-05-2002, 10:32 PM Thread Starter
amcpapa
i had 500 miles on a rebuilt short block when the thrust bearing and crank were wiped out on my 360 v8 . it's a j10 with a 727 trans what could cause it ?
amcpapa is offline
post #2 of 4 Old 05-06-2002, 09:46 AM
pop_r_master
Define wiped out. Did you see the bearing and crank? Was there score marks? Did the crank seize? Did you, during the rebuild, have the crank 1. replaced 2. cut and balanced (requires new larger bearings) 3. nothing and put back in. Did you torque the cap bolts to tight? Did the ears break off the bearing? Theres alot of different things that could happen. I rebuilt the 6 in my 79 cj....I didnt notice my the piece of metal shard that had somehow fallin onto the bearing when I torqued the cap on. I should have turned the crank by hand too....stupid me......lets just say it was an expensive mistake, the crank was to far gone to be reground......and I wasted the money on the dam oversize bearings....AHHHH.......Guess thats why I got the new TJ. Lemme know about the crank!
99 TJ 4.0 Bone stock.....You play CS? come to my server sometime, Id love to shoot you.
pop_r_master is offline
post #3 of 4 Old 05-06-2002, 10:07 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Chech the crank. some times there is a problem with the torque converter seating in the rear(wrong crank,forgot to remove the pilot bushing on a conversion,ect...).Contamination and inproper instalation aside,thrust bearing failure is usually caused by excessive pressure against the crank.
bazinga
jeepdaddy2000 is offline
post #4 of 4 Old 05-07-2002, 05:28 PM Thread Starter
amcpapa
by wiped out i mean the rear of the thrust on the crank was worn out about 1/4 inch. the motor was rebuilt by a shop in az. no the motor did not seize up it's still togeather but you can grag the front pully and move it back and forth 1/4 inch. this is the second time it's happened.it still has good oil pressure but the converter bolts are hitting the seperator plate .
amcpapa is offline
Rear main bearing too wide? cyoos Engines & Drivetrain 0 05-22-2009 03:29 PM
main bearing install write up ? mark12010 Engines & Drivetrain 6 10-01-2008 06:08 AM
Main Bearing condition? 258 whittlecj Engines & Drivetrain 0 09-30-2008 09:07 PM
oil leak & rear main bearing elfman69 Engines & Drivetrain 3 06-06-2007 06:24 AM
