Wont start when its hot - JeepForum.com
post #1 of 4 Old 10-18-2007, 01:24 PM Thread Starter
bfzmlp7
when i slow down to a stop light and if it quits due to on going carb trouble.
It turns over like the battery is dead and wont start and then if I let it set for about 5 minutes it will turn over at normal speed and fire up.
I have replaced battery and starter and it still does it.
I dont know what to check from here.
It wont idel after it gets hot either.
Thanks
bfzmlp7 is offline
post #2 of 4 Old 10-18-2007, 01:25 PM Thread Starter
bfzmlp7
Its a I6
Its a I6 !!!
bfzmlp7 is offline
post #3 of 4 Old 10-19-2007, 12:53 AM
cconn
Mud Bogger
cconn's Avatar
Sounds like a timing issue to me.
2013 Commando Sport. Rock Krawler 2.5" X-Factor lift. 35" MT/R's, 17x9 Pacer black wheels. ProRock 44 front axle. RCV shafts, ARB front and rear lockers. 4.56 gears. Coast 1310 drive shafts. TeraFlex adjustable tire carrier. AEV front bumper. Warn 9.5 CTI winch. TrekArmor seat covers, Spiderweb shade
Build Thread :
cconn is offline
post #4 of 4 Old 11-23-2007, 12:34 AM
ghost183
timing might be the culprit, but dont disregard that carb issue you have, chances are in your case, your dumping fuel into the cylinders when stopping, and being the cylinders are loaded with fuel, and incorrect timing, the starter cant turn the motor over effectively, check both , idle it for about 2-3 minutes, and while still idling, does the exhaust wreak of fuel?
ghost183 is offline
4.0l h.o. wont start giorno71 Engines & Drivetrain 5 01-14-2010 12:23 PM
1990 2.5L wont start... well, will start but not stay running. Shandley Engines & Drivetrain 2 11-22-2009 01:37 PM
98 XJ Wont Start PLEASE HELP!! takethisride Engines & Drivetrain 1 06-18-2009 05:32 PM
Wont start David Richards Audio, CB & Ham Radios, GPS, & Electrical 3 10-27-2006 10:18 AM
258 wont start rustyCJ Engines & Drivetrain 10 09-26-2002 08:35 PM
