Won't start, no power??? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Won't start, no power???
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome savings at openboxoffroad.comNitro Gear Packages Now Available at Rockridge 4wd
Unread 04-22-2004, 08:04 PM   #1
Broadway
I posted this thread on the Cherokee Board Please help if you can, I am running out of ideas. 1996 Cherokee 4.0L, Manual
http://www.jeepforum.com/forum/f11/no-electrical-power-78873/
2000 Black TJ Sport, FF14 bolt disk brakes Detroit and 5.13s, HP D60 ARB and 5.13s, TF727/Atlas 4.3, stretched 104" on 39" IROKS
Broadway is offline   Reply With Quote Quick reply to this message
Unread 04-24-2004, 11:19 AM   #2
jeepdaddy2000
1971 CJ5
YOur rig should be equiped with an emergency shut off switch which is designed to shut off the fuel pump in case of an accident. These are an inertia switch usualy located in the cab and are resetable. I am not that familiar with the system, so I can't give you more info. However, it might be something to look into.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 04-26-2004, 01:44 AM   #3
RedBug
Location: RAF Mildenhall/RAF Lakenheath, England with the Department of Defense
Shutoff valve??
Jeepdaddy2000,
Would there be an emergency shut off switch on the '95 Wrangler 4.0?? If so, would it be resetable and could it be done from the cab?? It would sure make my situation a lot easier if that were the case.
Larry
Larry Sanders
USMC Retired
[COLOR=Blue]For what's more honorable than scarrs, or skin to tatters rent in Warrs? --------Samuel Butler, Hudibras, 1658[/COLOR]
[COLOR=darkred]Wounds of the flesh a surgeon's skill may heal, But wounded honor is only cured with steel. ----19th century challenge to a duel[/COLOR]
RedBug is offline   Reply With Quote Quick reply to this message
Unread 04-26-2004, 07:19 PM   #4
jeepdaddy2000
1971 CJ5
These switches are required on all auto's that come stock with an electric fuel pump. These switches shut off power to the pump in case of an impact. This keeps the pump from contuniously running after an accident and potentialy causing a fire hazzard if a fuel line ruptures. As for your particular model, I can't help, as I am not very familiar with the systems other than know there are there. My suggestion is to call your local service department. They should be able to give you the information you need.
Unread 04-27-2004, 02:38 AM   #5
RedBug
Service Center in Britain
jeepdaddy2000,
Thanks for the reply. Unfortunately, I talked to the 'Auto Centre, Ltd' here in Mildenhall, England. They supposedly specialize in Chrysler, Jeep and Dodge. They seem to be about as familiar with Jeep as a caveman would be with a computer.
On the times I've been in there, there's usually only one tech, one parts/service rep, no parts that don't have to be orderd in despite the fact that there are British spec Jeeps (right hand drive) here. Their thinking is that by moving the steering wheel to the right hand side, every OTHER part on the Jeep is different as well. The wait time for parts is 1-2 weeks. Ridiculous. The prices are inflated too. A fuel filter here costs about $40, an O2 sensor runs in the neighbor hood of $150.
By the way,.......... what's a decent price on a fuel pump for the '95 Wrangler with a 4.0 I6?
The base parts store quoted me $306. Seems a bit high to me.
Larry
Larry Sanders
USMC Retired
Unread 04-27-2004, 07:10 PM   #6
jeepdaddy2000
1971 CJ5
Ok guys, update...NO jeep vehicle is equiped with an inertia switch. My bad on the misinformation. I know Fords have them and a service guy I know told me the "they all have them" line. Worry not, he is as we speak, nude, covered with honey, and staked out on an ant hill. So I broke down and called the local service center. According to the guru down there, an inoperative fuel pump can be caused by a blown fuse, bad ballast, bad relay, or bad pump.
Larry, a pump at the local auto parts store runs about 200$ US.
hope this helps.
Unread 04-28-2004, 12:07 AM   #7
RedBug
Thanks............
Thanks, jp2k,
I'll have to do a bit more research. Not sure where the ballast is. Which fuse would that be. The ignition fuse seems to be ok. Not sure of the relay or pump. I'd like to get by w/o having to change the pump but will if necessary. The cost of pumps I've seen at discountauto.com is $98 - $216. Your quote is right in the ball park. The Brits want to charge me 298 British pounds Sterling or right at $600 for the pump alone.
Can't afford that. Will need $$ for plane fare. I will most likely be coming back stateside in a few days. My sister died yesterday from cancer and my younger brother's great love of almost 35 years passed away a few hours before my sister, also from cancer. It's hit us hard, but I HAVE to get this Jeep up and running.
Thanks for everything folks
Larry
Larry Sanders
USMC Retired
