Won't always go into 4x4 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Won't always go into 4x4
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 11-15-2012, 10:55 PM   #1
akagrifty
Hey i got a stock 89 wrangler with 4.2 5 speed that doesn't go into 4x4 a lot. Any quick fixes for it? I am in the process of rebuilding my engine right now. So, I don't have a lot of money to get the kit to change it over to manually lock it. Oh I am new so once I get 25 post I will get some pictures on here of the engine rebuild.
akagrifty is offline   Reply With Quote Quick reply to this message
Unread 11-16-2012, 05:10 AM   #2
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's how the factory suggests you shift the transfer case and I've been doing this since these things were new and I worked at the dealership. Quoted from the owner's manual.
"To engage, shift the transfer case lever from 2H to 4H while the vehicle is moving at any legal speed". I let off the gas, throw the lever, and then tap the gas and let off.
4L position: " To engage, slow the vehicle to 2-3 MPH , shift the transmission to Neutral, then shift the transfer lever to the right and pull firmly rearward to 4L".
cruiser54 is offline   Reply With Quote Quick reply to this message
Unread 12-03-2012, 02:01 PM   #3
akagrifty
yeah my problem is not getting the jeep to shift into 4x4. The issue is that the front axle will not lock. I have seen some guys flipping the shift fork and always having the axle locked in 4x4. Has anyone done this and have you noticed any change in gas milage?
Unread 12-03-2012, 02:32 PM   #4
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Done it. No change in gas mileage. Here's how:
http://www.cherokeeforum.com/f51/fre...ss-91-a-38629/
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
