WJ long crank time - JeepForum.com
post #1 of 7 Old 09-04-2013, 03:06 AM Thread Starter
swquintal5307
WJ long crank time
I have a 2001 WJ 4.0 that runs great, once it's started. It cranks a very long time before it fires up. But it never requires a second try, just a very long first crank. I just put a brand new fuel pump in and a brand new fuel filter which has a built in regulator. So I'm not sure what can be causing this. I've tried turning the key to accesories to let the system prime but that doesn't help. The only other thing I can think of is the fuel pump relay? And btw I have a p0455 vacuum leak code could this be the cause?
Thanks for any help!
swquintal5307 is offline
post #2 of 7 Old 09-04-2013, 09:51 AM Thread Starter
swquintal5307
No one knows anything?
post #3 of 7 Old 09-04-2013, 02:53 PM Thread Starter
swquintal5307
Bump..
post #4 of 7 Old 09-04-2013, 02:56 PM
JeeperCreepers7
Try fixing what's throwing the code first
That could be causing some funkiness with your pcm...
JeeperCreepers7 is offline
post #5 of 7 Old 09-05-2013, 08:39 AM Thread Starter
swquintal5307
Can a p0455 vacuum leak cause long crank times?
post #6 of 7 Old 09-06-2013, 09:58 AM Thread Starter
swquintal5307
Bump...
post #7 of 7 Old 09-07-2013, 08:53 AM Thread Starter
swquintal5307
This is the worst jeep forum. No one knows anything.
