at wits end - Page 2 - JeepForum.com
post #16 of 21 Old 08-13-2013, 08:12 PM Thread Starter
singleshot
I entertained you laybackman...
Didn't do the trick, but I know where it's at now :-)
If it has fasteners, I can take it apart.... Putting it back together is the real question.......
singleshot is offline
post #17 of 21 Old 08-13-2013, 08:44 PM Thread Starter
singleshot
double post... sorry
post #18 of 21 Old 08-14-2013, 05:32 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
The reason I asked you to pull the plug on the VSS sensor is the fact that the VSS, the crank and cam sensor share the same 8 volt circuit. The VSS sensor can short internally causing no blown fuse but shunts that 8 volts to ground. Needless to say if the ECU does not see any input from the crank or cam sensor it will never start. It is a rare event but not impossible.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #19 of 21 Old 08-14-2013, 02:00 PM Thread Starter
singleshot
Moving along...
Pulled and reinstalled the crank position sensor and I got my fuel pump to run consistently when I turn the key to start (radio still won't work in that position, but will in the AC position).
She still won't run though. As I was laying out back by the tank and had my daughter try to crank it, I got an over-whelming smell of gas, so we are getting fuel now.
So I guess we are down to spark at this point... Time to pull the coil rail and the plugs to see what's going on down there I guess.
post #20 of 21 Old 08-14-2013, 07:34 PM Thread Starter
singleshot
Got the jeep started this evening; hurray for "makes no sense what's so ever".
I was moving stuff around that I had replaced, putting old parts back on and then taking them off when I started messing with the cam position sensor (a part I replaced from the start).
I had left the two small bolts loose while she cranked the engine over. As it was cranking, I lift the sensor up about 1/4 of an inch and the jeep started. I was able to bolt it down while it was running and she kept running.
I then had the wife shut it off and try to restart it with the cam sensor bolted down and it wouldn't work. I repeated the lifting it up while cranking and it started again.
So that's where I have left off for the evening. I moved the jeep closer to my work area so I don't have to walk around the house for every single little item I'm after and shut it down for the evening.
I should add; this works with both the old sensor and the new sensor... totally repeatable with both and yet will not start with it bolted down.
Any idea's ???
post #21 of 21 Old 06-18-2014, 06:27 PM Thread Starter
singleshot
I wanted to update this thread with an actual fix for the issues that remained:
Won't start consistently. (sometimes starts after several cranks, other times you'd run the battery dead trying).
No radio what so ever.
No back-up lights.
Air bag lights up and beeps shortly after it would actually start.
Blower motor wouldn't blow.
No rear defroster and or the defroster light would show on w/o me turning it on (it was never actually on at anytime).
After all I've replaced, the piece that cured all of the above was the ignition starter switch.
I tore into it in frustration and found that a good portion of the copper contacts inside were corroded to the point of being green.
A new one from NAPA ran me $27.00
Anywho, I'm headed out now to button it up and give her a badly needed bath.
