Wiring an MSD in a YJ - JeepForum.com
post #1 of 5 Old 04-15-2004, 07:26 AM Thread Starter
Bullet-Proof
I posted in the YJ Forum before but no one was able to help me!!
Well, I have a new MSD 6AL + Blaster 3 coil. When I wired it in my friends 1993 jeep, it would NOT start!!?? I wired an MSD 6 before in a 1997 chroke and it worked fine... Is there difference in 93 wrangler and 97 Cherokee in terms of MSD wiring??
I wired the white wire of the MSD to the -ve wire which was connected to the coil, is this right? or should it be connected to the Distributer?
Thanx in Advance
Bullet-Proof is offline
post #2 of 5 Old 04-15-2004, 11:06 PM
mde
I'm running into the same problem but with the Mallory HyFire system. I do believe you can use either or. Meaning the white wire trigger to negative coil wire or the purple and violet wires to the Dist. Let me know how it turns out.
Matt
89' YJ
AMC 258, all mods
7" SOA BF 35" mud terrain
mde is offline
post #3 of 5 Old 04-16-2004, 04:57 AM Thread Starter
Bullet-Proof
Thanx for the reply
Well, I did connect the white trigger wire to the negative coil wire, but the car will not start. I also noticed that there is low voltage on the msd red wire which I connected to the positive wire of the coil. I also forgot to mention that when I first installed the MSD in the YJ, the battery got weak. Also when am trying to turn ON the car with MSD, I use jumpers... Could this be the problem??
post #4 of 5 Old 04-16-2004, 10:12 AM
mde
I'll tell you one thing if it is draining your battery something is wrong. Do you have an installation manual? All the wires are going somewhere, except of course one of the trigger wires. For me it's been a long process of trial and error. Still havn't got it right.
You should have at least 12V coming off the positive lead ( originally connected to the coil ) to the small red wire on the MSD box. Take a meter to it and see. If not 12V than you will have to cut back the resistor wire until you achieve 12. Also make sure you have a solid ground for the MSD box.
If you get it working or have anyomore problems let me know.
cheers
89' YJ
AMC 258, all mods
mde is offline
post #5 of 5 Old 04-16-2004, 10:26 AM
Joseph Humphrey
Joseph Humphrey's Avatar
i had some problems when i wired my msd 6 box into my zj. i called the msd tech support line and they talked me through the install (ie which wire to connect where) intill we found the missed / wrong connection and it fired right up.
give them a call and they will help you fix it. unfortunately its not toll free....
The Almighty 2" BB Jeep Club Member #34 (no more BB)
Silver 98 ZJ 4.0 I-6
K&N FIPK Gen II
JKS Adjustable Track Bars F and R
JKS Adjustable Control Arms
JKS Quicker Disco's
Kevins 3.5" Lift Kit w/ MX-6 Shocks
US Wheel 15x8 10 spoke black Steelies, 31" BFG AT KO rubber
Joseph Humphrey is offline
Wiring Gurus - A/C wiring question Giviner Audio, CB & Ham Radios, GPS, & Electrical 4 11-30-2009 09:08 PM
wiring in series vs wiring in parellel CCJ Audio, CB & Ham Radios, GPS, & Electrical 25 01-27-2009 12:35 PM
Roll your own wiring~OEM style connectors~take THAT Overpriced Painless Wiring turbogus Fabrication Shop 4 01-22-2009 08:16 AM
Wiring multiple amps/speakers SirGCal/Wiring experts! omnipseudo Audio, CB & Ham Radios, GPS, & Electrical 4 09-24-2004 06:02 PM
