**UPDATE**
I learned I am an idiot, and didn't truly have the spark plugs out (open mouth, insert foot) -- So I redid my test today.
Just to confirm, cold engine - all plug wires labeled and pulled off and out of the way, coil disconnected, plugs removed...
first test was with dry cylinders
cyl 1 - 127
cyl 2 - 140
cyl 3 - 160
cyl 4 - 155
cyl 5 - 160
cyl 6 - 115
with 8ml of motor oil injected and then the same test performed:
cyl 1 - 115
cyl 2 - 160
cyl 3 - 180
cyl 4 - 190
cyl 5 - 200
cyl 6 - 140
I also hooked up the leak down gauge and pushed 100 psi in and all cylinders held air for 10 minutes each -- no loss whatsoever.
I put in the new champion stock plugs I was going to put in our YJ in(since they were there) and took her for a test drive, still nothing -- of course I was burning off all the oil in the cylinders so I have lots of white smoke. Still won't go over 40 -- I am wondering if my problem is elsewhere(ie fuel pump) -- It still starts and idles fine, but when you give it more than 1/4 throttle it misses terribly...
Sorry for the initial screwup - I have seen the errors in my ways and I appreciate the help....
I can post pics if someone really wants to see what a POS jeep looks like
Justin
