will a T3 match up with a 4.0 that was with an automatic transmission - JeepForum.com
post #1 of 4 Old 11-10-2013, 04:35 PM Thread Starter
Renegade191
I have a 82 CJ7 with a 4.2 and a 4spd T3-51-097-901 transmission, I bought a 4.0 from a 96 Cherokee that had a automatic transmission. Can I use my trans with the 4.0? And how do I get them to match up if I can?
Renegade191 is offline
post #2 of 4 Old 11-12-2013, 06:56 PM
uberxj92
1992 XJ Cherokee
If I remember right the 4.2 & 4.0 blocks were very close. I think the bell housing's should interchange. I may be wrong.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 4 Old 11-12-2013, 07:59 PM
rjbruzan
What is the final result. If its a fuel injected 4.0 connected to the T3 you will need to get an alternative crankshaft position sensor location.
Its a direct bolt in if you are planning on running an HEI distributer and a carb. The AX-15 bellhousing has a hole for the CPS to bolt in.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #4 of 4 Old 11-13-2013, 02:05 AM
mmerlinn
No such transmission. Those numbers should be "13-51-097-901".
Further, those numbers occur on BOTH 4-speed and 5-speed transmission top covers, both 2wd and 4x4, many gear ratios, and from the early 80s through 2002, so they are useless for identifying a transmission.
mmerlinn is offline
4.0 swap , cj7 , transmission
