will a 2000 4.0 go in my 91 yj? - JeepForum.com
post #1 of 4 Old 06-28-2012, 06:20 PM Thread Starter
shaneo318
The 4.0 made it almost 300k miles, then took a crap! I found a whole 2000 grand cherokee for 200 bucks. Will it fit? Will the obdI computer let it run? I can swap manifolds and all the little things if need be, as long as the block bolts to the ax-15 and the motor mounts are close, I can rig something up! It's only a mud buggy!
p.s. I did a search and found nothing.
shaneo318 is offline
post #2 of 4 Old 06-29-2012, 04:29 PM Thread Starter
shaneo318
Nobody knows?
post #3 of 4 Old 06-29-2012, 04:42 PM
IslandHopper
The block is the same... It'll fit on the mounts and mate to the trans.
The wiring and sensors are different ... for the OBD2 setup.
It's certainly be easier to find an OBD1 engine. If this is all you can find, then it'll work, but it'll be a bit of a puzzle to get everything working correctly. (Then again, if it's not a road-car you may not care about anything but making it run well... sensors and lights be damned!)
IslandHopper is offline
post #4 of 4 Old 07-04-2012, 03:13 PM Thread Starter
shaneo318
Sweet! Thank you!
2000 TJ What AX-15 will interchange? rickknecht Engines & Drivetrain 0 10-31-2009 07:13 AM
95 hp30 into my 2000 xj mg2000xj Engines & Drivetrain 1 10-28-2009 12:40 AM
2000 5.3 slafferty Engines & Drivetrain 5 02-12-2009 08:49 PM
4.7 2000 Wj raider650 Engines & Drivetrain 1 07-24-2008 08:55 PM
Sub for 2000 TJ ForeverTheOptimist Audio, CB & Ham Radios, GPS, & Electrical 4 09-02-2004 03:16 PM
