Wide open throttle, not so wide open! - JeepForum.com
post #1 of 5 Old 02-22-2011, 12:58 PM Thread Starter
iDriveYJ
I noticed a while back that my throttle doesn't seem to move as far as others so I but a brick on my gas petal and looked at my butterfly valve its only about 75% open i can still pull the rocker on the throttle body about 1/4 turn until it is truly wide open. I do have a one inch throttle body spacer installed, maybe that is where the slack is coming from. Any help or advice would be appreciated. After all [more air+more fuel=more power]
iDriveYJ is offline
post #2 of 5 Old 02-22-2011, 01:12 PM
MONSooNmonkey
did you adjust your throttle cable after installing the tbs?
Sadface :(
MONSooNmonkey is offline
post #3 of 5 Old 02-22-2011, 01:30 PM Thread Starter
iDriveYJ
Nope would I just cut and recrimp the ball on the end to make it shorter?
iDriveYJ is offline
post #4 of 5 Old 02-22-2011, 01:32 PM
MONSooNmonkey
Normally have an adjustment where the throttle cable is attached by the intake.
Sadface :(
post #5 of 5 Old 02-22-2011, 03:00 PM Thread Starter
iDriveYJ
I only saw a ball and socket style retainer but I rigged it up so it opens all the way now the city difference is little to none but the higher rpms like highway travle and top end accel. Are moderatly better
iDriveYJ is offline
assistance , performance , troubleshooting , YJ
12.50 wide tires on a 10" wide wheel WILLY348 Tires & Wheels 13 05-19-2011 06:24 PM
Would... (11.50 wide tire on 8" wide wheel) luv2getbig Tires & Wheels 2 07-17-2009 10:02 PM
how wide of rim do i use on a 14inch wide tire? TXjeepTJ Tires & Wheels 2 05-18-2006 05:17 AM
10.5 wide tire on 7" wide rim arcteryx23 Tires & Wheels 8 02-19-2006 05:06 PM
