Why replace the engine? - JeepForum.com
post #1 of 5 Old 07-07-2001, 01:44 AM Thread Starter
Rob Patrick
I'll admit I'm pretty green to all of this, but why would one need to swap engines (assuming, of course, that the existing engine still works.)
For off road, with a low range xfer case, it seems like the need for power is minimal and the stock engine should work fine.
Is there something I'm missing???
2000 TJ Sahara - Bone Stock (so far...)
Rob Patrick is offline
post #2 of 5 Old 07-07-2001, 03:38 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Very simple .. a standard engine that you have and all your other friends have allowes simple fixing and repairs on the trail ..
Also, with certain mods, you need a type of engine to match ..
You wouldn't want to spin 44" Swampers with the stock 4banger .. or even the baby 6.
Laters!
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 5 Old 07-08-2001, 04:31 PM
hamyscj
Mostly it is a "testosterone, bigger is better, AU, AU, AU(think "tool time") got to have it" kind of thing. But there are some occations that horsepower is needed more than gearing. If you have a bigger engine then you have to have heavier rears, etc, etc.(see quote above ) Simply put, we don't but it sure is fun.
One Way Up Racing
Romans 10:9
hamyscj is offline
post #4 of 5 Old 07-16-2001, 03:54 AM
Tonka
2015 JK Wrangler
I want to swap to a 4.0 for more power(have 2.5)the 2.5 is a little sluggish on hills and the freeway
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #5 of 5 Old 07-27-2001, 07:36 PM
NaeKid
NaeKid's Avatar
I have a 4.2 that you can have for fairly cheep .. I want a 350 in my Jeep now! C'mon up and we can get started
Silver
NaeKid is offline
bad Cyl. head... Rebuild or replace? Possible engine swap? BigDumbBear Engines & Drivetrain 0 02-14-2009 03:51 PM
Fix or replace? Dmrennells Engines & Drivetrain 1 03-24-2007 08:33 PM
Electric Fan to replace Engine Fan Difranco Engines & Drivetrain 5 09-05-2006 04:30 PM
4.0L MFI to replace older 4.2L Carb engine dremblewedge Engines & Drivetrain 5 03-10-2004 01:30 AM
replace 4cyl engine with 6cyl engine eastwood Engines & Drivetrain 5 01-23-2003 08:19 PM
