Who reprograms stock Jeep ECU's for boost?? - JeepForum.com
post #1 of 4 Old 03-15-2006, 03:41 PM Thread Starter
WRXINTX
Anybody do this on here???
obviously I know I will need a 2 bar map sensor from a turbododge or something like that... I plan on running less than 15psi... I am thinking around 10psi max on stock pistons ...
any input on the strength of stock pistons under boost???
I am thinking about a rear mounted turbo kit on my 91 Cherokee 2wd with 4.0L/ AW4 tranny....
that or a supercharger on it....
Thanks!
RYNO
WRXINTX is offline
post #2 of 4 Old 03-21-2006, 04:49 AM
TurboTJ
I have a 99 TJ 4.0 running 7.5 PSI of boost but am pulling out some timing to keep the engine from knocking. For fuel you can either run a FMU or a computer modified signal. I started out with the fuel management unit but am switch to the computer. The FMU works by boosting the fuel pressure as soon as you hit boost. With this mod, the map sensor is left stock. The computer modifies the map sensore voltage and tells the ECU to inject more fuel. This is the better of the routes if possible. Either way, the guys to talk to are 505 performance. They are producing TJ turbo kits.
www.505performance.com
TurboTJ is offline
post #3 of 4 Old 03-21-2006, 05:18 AM
wildman4x4nut
wildman4x4nut's Avatar
There is a company in Calif that make a piggyback computer that will work on our Jeeps. Look up SplitSecond and look at their FTC1 or FTC1E also give them a call and discuss what you are doing. And 505 is sourcing their computer stuff from SplitSecond last I heard.
WILDMAN
Cle Elum, WA
wildman4x4nut is offline
post #4 of 4 Old 03-21-2006, 06:34 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
These guys did my 4.3 computer, http://fuelairspark.com/
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
94 Jeep Cherokee Sport, stock rims winter tires Is smaller then stock an issue? brahm Tires & Wheels 6 01-07-2009 03:31 PM
Jeep Grand Cherokee 3.1TD No Turbo boost? dave1975 Engines & Drivetrain 1 08-30-2007 03:36 PM
Budget boost with stock shocks MikeTJ Tires & Wheels 5 07-20-2007 08:20 PM
Is it possible to add aux in for stock jeep radio? jzmtl Audio, CB & Ham Radios, GPS, & Electrical 3 03-18-2007 07:11 AM
Full Traction 2" boost lift or RE buget boost pete1182 Tires & Wheels 3 11-29-2006 08:19 PM
