#1 | |
who makes the best spark plug?
I'm gonna be replacing my plug wires and plugs soon, and I've never done it before. Just wondering what plug to go with.
Duvie 95 YJ 2.5L 5 Speed Fightin a war against Florida Rust! |
#2 |
Bosch Platinum 4 plugs I here are the best by far, at about $5.00 each. You can never change the gapping though but why would you want to whe they are preset.
I'm out like a fat kid playing dodgeball..... Matt |
#3 |
I don't know much about spark plugs but Bosch is the best. As for any performance difference, I dought that you could ever find one that made a power increase. I've heard that platinum plugs take less voltage to make a hotter spark but foul out easier if you engine burns any oil. I'd save my money and buy a regular Bosch plug set. If you ever want to upgrade your ignition to say MSD or Jacobs you would need to open up your gaps and you can't with the Platinum 4's. As for wires, any 8mm will work good.
Josh |
#4 |
thanks alot guys, I think I'll go with bosch then.
#5 |
Before you replace your wires you may want to decide if you are going to want to do the "TFI" ignition upgrade. If so you can pick up the cap, rotor and adapter you need and buy the appropriate wires. You can always purchase the TFI coil later, or just buy a perfromace coil for the duraspark like the "blaster 2F' and it will mount in the existing coil bracket and use the horseshoe connecter.
#6 |
My 4.2 loves Bosch Platinums. The +4's are probably a waste of money. The Juice Box ignition system is the best $130 I ever spent on my Jeep. Definitely a "Best Buy", two thumbs up.
'87 Wrangler YJ 4.2 I6 (sorry, sold) JuiceBox ignition 2 1/2" ProComp Lift 31" BFG A/T's K&N Filter Custom Rock Guards Turbo Muffler Rear Track Bar in the shed Other Tricks I won't tell to just anybody! '99 Grand Cherokee 4.7 V8 Towing Package K&N FIPK ProComp MX6 shocks Borla Exhaust Tow Hooks Alpine CD with Infinity+iPod connect Just getting started! If you're not living on the edge... you're taking up too much space. |
#7 |
I could be wrong, but I've been told that platinum plugs are not supposed to be installed in chrysler vehicles. When my dad put the platinums in his cherokee, it was a huge mistake and he went back to the regular copper; and it runs well now. It also depends on what works with your jeep. Experiment!!!
#8 | |
www.lp.org
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? " Roger Waters |
#9 |
www.pulstar.com
i'll be going with them when it comes time to change. I work with an Electrical Engineer who swears by them.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#10 |
You guys gotta be kidding me, do you know anything about spark plugs?
They best plugs to run in your YJ are the OE spec'd ones - probably Champions. Bosch plugs are a joke, I haven't talked to anyone that likes them in a variety of different vehicles. Also, don't waste your money on plugs like the Bosch +4s, +2s, or AC Delco Splitfires. The spark will NEVER arc across all 4 of the electrodes - it will always follow the path of least resistance and I guarantee that Bosch's manufacturing tolerances aren't tight enough to guarantee the gap on the electrodes is so close enough between all 4 that the spark arc's across all 4 electrodes. I haven't heard much about the Pulstar plugs but I am a bit skeptical of those as well.
Andy '98 Jeep ZJ "Pearl" |
#11 |
Go STEELERS!!!!
Many TJs do not like the platinum plugs that have the platinum on one side of the electrode only. Either has to be on both sides or none at all. Champion truck plugs have worked well for me so far.
#12 |
Just violated my Parole
i use champion truck plugs. i like them much better than the NGk pieces of crap that it came with
#13 |
Just go with Champion plugs, you can substitute a junkyard Ford coil for the existing coil the addition of an MSD 6a might be worth while if you go off road. I don't know about the availability of a larger high voltage cap but if you change the cap/rotor get the larger ones if you can and if they will fit and always get a cap with brass terminals inside (you might have to spend a bit more at NAPA); aluminum terminals in ignition caps will give problems eventually.
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway. Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road. |
#14 |
Bosch plugs are great if you like spending 3x more on an item that doesn't work as well as a plain old Champion.
But hey....its PLATINUM and has all those stupid shaped electrodes, so it must be better! |
#15 |
I ended up on a website for E3 Sparkplugs. Im not going to drop the link to the site cause I am new and do not know the rules just yet but just add a dot com to the name. I scrolled down to the bottom to learn more about the plugs and it seem to be possibly a new plug to consider. I would be curious to hear some people that know a bit more about plugs tell me what they think. They crap or are they in the right direction?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
