WHite smoke - JeepForum.com
post #1 of 9 Old 02-20-2003, 01:55 PM Thread Starter
Joe jeep
WHite smoke
On cold starts white smoke is being blown out the muffler
i was in a hurry to get to school so i did;nt have enough time to check how long it would last so when i got to my destination and parked, i looked to see if it was still commin out. Luckily it wasn't, so i forgot about it. but what does white smoke mean?
ive heard of black smoke being bad gaskets around those things but not white
thax for any suggestions in advance
Black 88 YJ 4.2L.
Hurculined Front Grill and Fenders
TRAILAMSTER 2" LEAFS.
RANCHO RS 5000's.
OPTIMA RedTop.
31"BFG'S A/T.
HEI DISTRIBUTOR W/EXTERNAL COIL, BOSCH+2'S
M.O.R.E Boomerang greasable shackeles all the way around.
Hood lock
Joe jeep is offline
post #2 of 9 Old 02-20-2003, 02:52 PM
johny1i
johny1i's Avatar
If it disappears within 10 feet or so, it's just steam. If it's bluish-white and doesn't dissipate, then it's oil that's probably getting around your valve guides or possibly the piston rings. Probably a good idea to pull one of your spark plugs and see if it's covered in oil. If it's not bad enough to foul out your plugs or suck up a quart of oil each week or two, then you're okay for the time being. You've seen those cars on the road that are puffing that smoke continuously--that's how yours would be eventually but it can take 50,000 miles to get that bad compared to how it is right now (just doing it on startup after sitting overnight).
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
post #3 of 9 Old 02-20-2003, 06:18 PM Thread Starter
Joe jeep
OIL
Actually my oil level is really steady since the change.
tuesday night i pulled the spark plugs out and set the gaps. i did notice some oil around the where it gets screwed in. not to much tho. i just got an old tooth brush and wiped them to death, so their fairly clean now.
if this gets worse in the future, do u think an average home mechanic person like my self, with a haynes manuel by his side will be able to change the valve guides or the piston rings by himself or with a friend, possibly?
Black 88 YJ 4.2L.
RANCHO RS 5000's.
OPTIMA RedTop.
31"BFG'S A/T.
Hood lock
Joe jeep is offline
post #4 of 9 Old 02-20-2003, 07:06 PM
johny1i
johny1i's Avatar
Don't sweat oil on the threads, it's when the ceramic insulator or electrode is black with oil that you have to worry because it will essentially short-out the plug.
Somebody on here may have experience replacing valve guildes themselves, but my dad and I always left that up to the machine shop when redoing old engines, etc. By the same token, if you're going to go to all the trouble of pulling the pistons, I'd probably just hold off until you need to rebuild the engine and/or head.
I'll let someone else add to this--
johny1i is offline
post #5 of 9 Old 02-22-2003, 02:35 PM
Birdawg
Birdawg's Avatar
I am not too sure on your engine but, I have worked on a lot of diesels..... same may apply..... Dark smoke from a diesel's exhaust means unburt fuel being expelled, caused by not enough air getting into the cylinders to burn the fuel or too much fuel getting into the cylinders for the amount of air supplied. Either way it is too much fuel or not enough air. White smoke from a diesel normaly just the oposite,... not enough fuel and/or too much air. I realize this is for a diesel but if you are not burning oil it could be the air/fuel mix is off..... ?? Just a thought.
1992 YJ 4.0 Liter HO I6
Sitting on a Rock in the Bay
Air Restrictor & Chicken Bones Gone,20 Gal.Gas Tank :) Audiovox CD Sound Bar, Front Tow Hooks. Hard & Soft
Tops. 31" x 10 1/2" x 15" Coopers
Sumer Projects:2 1/2" Rubicon Express.(Done) New Metalic Paint.(Done)
31" Tires (Done), Bed Liner. Dome Light for Soft Top
Blue Jeep Member #15
Birdawg is offline
post #6 of 9 Old 02-23-2003, 07:26 PM
4wheeler4CJ
4wheeler4CJ's Avatar
It's probably steam....but if it is excessive, it will likely be coolant getting in your cylinders from a head gasket or intake leak. Sometimes you can have one of these leaks when it is cold, and it is minor enough to stop when the engine is hot and the metals all expans and tighten up the leak.
Just keep an eye on it for now. If you notice it change or last a long time, have it checked.
4wheeler4CJ is offline
post #7 of 9 Old 02-24-2003, 11:13 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
The rule of thumb is -
white smoke = radiator fluid
blue smoke = oil
Have you checked your rad-fluid lately? Your head-gasket might just be leaking enough that on start-up its burning antifreeze as well as gas.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #8 of 9 Old 02-25-2003, 11:15 AM Thread Starter
Joe jeep
NaeKid, when u say head gasket, do u mean, headers/intake, OR engine head.
Black 88 YJ 4.2L.
RANCHO RS 5000's.
OPTIMA RedTop.
31"BFG'S A/T.
Hood lock
Joe jeep is offline
post #9 of 9 Old 02-25-2003, 04:35 PM
Fallout
Fallout's Avatar
He means the head gasket. not uncommon up hear, negitve bloody cold + not plugging in the block heater can = cracked water jacket or head gasket or frozen lower rad hose is a good one that means that you WILL over heat even at -20 or 30 which will give you a cracked head or head gasket.
Don't ask, I do know this is fact as stupid as it sounds.
My pos DD
90XJ Laredo 4.0L(now HO) Auto, 6.5"lift, 36"x12.5"SSR's, custom this and that (snorkle, rockers, bumpers, etct), winch, lights, more crap to come.
Wife's DD
90XJ Ltd Up Country, Bored and stroked 4.7L I6 Auto,
2.5" lift 31x10.5"Hankook AT's.
Fallout is offline
Smoke with no CAT aerospace Cheap Tricks & Fixes 3 06-20-2009 02:33 PM
mufller spits water and blows out white smoke. whats wrong? incagoldjeep Engines & Drivetrain 11 02-15-2009 06:49 AM
Smoke RoadStick Engines & Drivetrain 3 08-05-2004 06:20 AM
White smoke out of dipstick? kingjrk Engines & Drivetrain 7 05-16-2003 07:20 PM
White smoke Jami Engines & Drivetrain 2 09-23-2002 05:56 PM
