where did the oil go??? - JeepForum.com
post #1 of 7 Old 03-19-2006, 01:35 AM Thread Starter
fire521
i have a 93 yj I6 it has 146,000 on it and the motor blew up, went to a salvage yard and picked uoe up that had 50,000 on it now the problem it has been in for approx. 4000, miles and i have had to add 2 qts. to it but there is absolutly no smoke from the exahust, no leaks, so where did it go? did the TJ goblins come and try to wreck my yj by stealing oil? or is there some other explination i am missing?
fire521 is offline
post #2 of 7 Old 03-20-2006, 12:32 PM
Fullsize_CJ5
It prolly burned the oil, you just didn't see it. ALL engines burn oil, they have to. The oil on the cylinder wall is what ultimately seals the cumbustion chamber, every time it fires a very tiny bit of oil burns away. But with worn rings or valves you'll burn a lot more. I'd check the compression and see what the rings and valves look like.
79 CJ 5, fiberglass tub on a cut down full size chevy frame. Full width axles GM 14 bolt in the rear. Dana 60 up front both with 5.38 gears. 350/400 turbo, np205 transfer case. Custom built modified 3 link rear coil spring suspension in the back, skyjacker leafs in the front. 44X18.5 gumbo mudders. 104" wheelbase hood and doghouse stretched 13" . ramsey 8000lb winch.
Fullsize_CJ5 is offline
post #3 of 7 Old 03-21-2006, 06:43 AM
75SV1
Is that with the 4.0L or the 258? Two quarts in 4K isn't a bunch. Still, I'd look at the PVC valve of CCV tube (if 4.0). Also, some people rav about AutoRX. Your rings might be sticking. Other problems could be vavle guides worn.
Tom
75SV1 is offline
post #4 of 7 Old 03-21-2006, 08:36 AM
de6w6it
Valve stem seals, piston rings, valve guides could all be suspect...
'66 Mustang/200/C4/ground up resto
'88 4 runner/SAS/22re/W56/duals/31's DD
Build:
de6w6it is offline
post #5 of 7 Old 03-22-2006, 10:08 PM Thread Starter
fire521
it is the 4.0 iwill check the compression tommorow and let you all know, also never herad of autoRX what does it do and wheere can you get it? thanks guys
fire521 is offline
post #6 of 7 Old 03-23-2006, 09:36 AM
75SV1
Auto RX is a flush or conditioner. I haven't used it, but many say its the best.
http://www.auto-rx.net/
Also, you might try Sea Foam. Its avialable at NAPA, I think. I have used 'Motor Flush' in the past with no ill effects that I know of. Still, many think its a bit harsh and has been know to cause problems. Berrymann's B-12 is simular to Sea foam. It might be worht a try.
Tom
75SV1 is offline
post #7 of 7 Old 03-23-2006, 10:32 AM
75SV1
You also might try a different brand of oil. What type and brand of oil do you use? Also, oil filter? I've heard of some people using different oil and they have less oil consumption.
Tom
75SV1 is offline
