Where is the Crankshaft Position Sensor??? - JeepForum.com
post #1 of 3 Old 11-23-2008, 03:17 PM Thread Starter
ScottN3N
I have been unable to find the crankshaft position sensor on my 94 Grand Cherokee 5.2L. It is supposed to be on the top right side of the bell housing - according to the manual. It is almost impossible to access this area - even visually. I have an idea what it is supposed to look like according to pictures, but no luck finding it. I felt a wire that goes into a rubber grommet, but no bolts or screws around it & nothing that feels like the sensor (the wire just goes into the grommet). Any ideas on how to get to it & change it out, please? Does this involve lowering the engine? Thank you.
ScottN3N is offline
post #2 of 3 Old 11-26-2008, 12:29 PM
Silver yj
1) Disconnect battery ground cable.
2) Remove spark plug cable loom at right rear valve cover.
3) Disconnect 2 hoses at EGR valve. Note position of hoses before dissconnecting.
4) Disconnect electrical connector and hoses at EGR transducer. ( Note hose position )
5) Remove 2 EGR valve bolts and remove valve.
6) Disconnect connector at oil pressure sending unit
7) Remove oil sending unit.
8) Loosen EGR tube mounting nut at intake manifold. Remove EGR tube mounting bolts at the exhaust manifold and remove EGR tube.
9) Disconnect crankshaft position sensor electrical connector.
10) Remove crankshaft sensor bolts and sensor.
Silver yj is offline
post #3 of 3 Old 11-26-2008, 10:35 PM Thread Starter
ScottN3N
Got it. Thanks. I need another joint between my wrist & my elbow. It fixed my problem. Now on to the brake problem.
ScottN3N is offline
crankshaft sensor 93 jeep grand cherokee rpprincess1981 Engines & Drivetrain 0 11-01-2009 12:37 AM
EGR position sensor? delta490 Engines & Drivetrain 0 05-14-2008 11:09 AM
Crankshaft Position Sensor????? thjofe Audio, CB & Ham Radios, GPS, & Electrical 2 09-26-2006 11:27 PM
Cam Position Sensor AZG23 Engines & Drivetrain 0 03-02-2006 10:46 AM
1997 4.0L Crankshaft Position Sensor Brian's 97 ZJ Engines & Drivetrain 0 12-08-2004 07:50 PM
