When the Engine Meets a lot of Water - JeepForum.com
post #1 of 7 Old 01-26-2005, 02:10 PM Thread Starter
Jerry All-Bran
Jerry All-Bran's Avatar
Is it bad for the engine or radiator to be engulfed in water when passing through a stream that covers the clutch and brake pedals? Where would you have to specifically clean to get the guck that get's stuck. Why would you need a snorkal? (I understand that the engine needs to breath so it keeps turning but not sure where or why or how). Just that spring is going to be here soon and I wanted to test out my jeep
Jerry All-Bran is offline
post #2 of 7 Old 01-26-2005, 02:39 PM
JSBlu974X4
should be fine, just as long as your intake doesnt go under, if you get a snorkel, which raises your intake to over your hood. after going through deep water, clean out your diff, change oil, tranny fluid, and x case
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #3 of 7 Old 01-26-2005, 05:16 PM Thread Starter
Jerry All-Bran
Makes sense I guess...how long do i have after I hit highwater to clean all that stuff?
post #4 of 7 Old 01-26-2005, 05:31 PM
JSBlu974X4
i usually do it when i get home or my next chance.
post #5 of 7 Old 01-26-2005, 05:45 PM Thread Starter
Jerry All-Bran
Guess there's more research headed my way heh. Still trying to orient myself with engines and the like ever since I got my jeep. Thanks for your patience!
post #6 of 7 Old 01-26-2005, 06:19 PM
94YJ H.O.
Yeah, water is non-compressable....trying letting your engine down a few gulps of it and see all the fun twisty shapes your connecting rods make
1994 YJ 4.0 H.O.
3-speed Auto
My NEW
Score: 406RRv1.0 with a BOA of 31.60
94YJ H.O. is offline
post #7 of 7 Old 01-27-2005, 09:13 AM Thread Starter
Jerry All-Bran
Maybe I'll do that, that way I'll have an excuse to buy 6cyl Although I like my 4cyl, won't sink in mud as much as a 6 Those few extra kilos count! heh
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
97wrangler Automatic and 4 cylinder engine. THINKING ABOUT AN ENGINE SWAP AND MANUAL BoatsJeep Engines & Drivetrain 0 11-12-2009 07:01 PM
Anyone use an engine lift plate with a leveler to pull an engine? tankcj Engines & Drivetrain 2 08-06-2008 02:29 PM
Water proofing for water crossings kchan2752 General Jeep & Off-Road Equipment 1 05-02-2004 08:12 PM
Water Proofing, or Water proof Alternators? DaveFL General Jeep & Off-Road Equipment 5 06-15-2003 04:03 AM
