Wheel bearing issues - JeepForum.com
post #1 of 4 Old 04-06-2012, 07:03 PM Thread Starter
Gh0st
So about 6 months ago the left rear wheel bearing in my 2001 TJ bit the dirt. I let a local mechanic replace it mainly because i didn't have a bearing press. About 2 weeks ago a familiar grinding noise started coming from the same tire and in my opinion the bearing is shot again. Has anyone else had this problem and if so what would cause it?
To hell and back.
Gh0st is offline
post #2 of 4 Old 04-08-2012, 09:14 AM
wgirvine
1992 XJ Cherokee
I'm not familiar with a TJ but in general there are lots of reasons for this... could be he installed the wrong bearing (not likely). Or he installed the bearing by hammering on the outer race, instead of pressing on the inner race (lots of idiots do this.) Did he refill the differential? Did he check to see if the axle is straight? Good luck...
The road goes on forever, the party never ends....
wgirvine is offline
post #3 of 4 Old 04-08-2012, 02:36 PM Thread Starter
Gh0st
The axle was replaced when the bearing was. And he did fill the housing back up with fluid. Apparently I got lucky and it was just brake shoes sticking. After a little brake cleaner everything started to work like it should.
To hell and back.
Gh0st is offline
post #4 of 4 Old 04-09-2012, 07:40 AM
wgirvine
1992 XJ Cherokee
wgirvine is offline
Wheel bearing selection? DrBygstan General Jeep & Off-Road Equipment 2 03-11-2012 01:03 AM
Rear wheel bearing rubber01 Engines & Drivetrain 0 12-16-2011 04:02 PM
Wheel Bearing, CV Joint, or Differential tank12983 Engines & Drivetrain 0 09-09-2011 02:54 AM
Dana 44 Wheel Bearing Help lawson1603 Engines & Drivetrain 1 07-02-2011 02:39 PM
D35 rear wheel bearing question... Mike97ZJ Engines & Drivetrain 0 11-07-2009 09:49 AM
