what is wrong - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > what is wrong
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!
Unread 07-04-2012, 03:26 PM   #1
thetbjeeper
what is wrong
When I turn the key on my 92 wrangler it spins like its trying to start but I'm not getting spark that's simple to fix my issue is if I hold the key long enough I get a clunk while its trying to turn over
thetbjeeper is offline   Reply With Quote
Unread 07-05-2012, 11:00 AM   #2
Mishimoto
Is it a clunk or a cough? How long are you cranking the engine? I've seen starters seize because they get too hot from continuous cranking and heard plenty of loud coughs from engines that can't ignite the fuel. What engine do you have?
Mishimoto is offline   Reply With Quote
Unread 07-05-2012, 11:22 AM   #3
thetbjeeper
I have a 4.0 straight 6 it sounds like a clunk it move the whole jeep.
Unread 07-05-2012, 11:34 AM   #4
Mishimoto
Automatic or manual trans? How are you engine and trans mounts?
Unread 07-05-2012, 02:16 PM   #5
thetbjeeper
Manual...I really don't know about mounting its stock if that helps I don't think its the trans but that's the area it seems to come from rear of the block on the bottom
Unread 07-06-2012, 08:04 AM   #6
Mishimoto
The engine and trans have rubber mounts, and with time/miles they go bad. If they have excessive movement they can let the drivetrain slop around when torquing it and cause a clunk that would move the whole vehicle. Do you have any idea why you have no spark?
Unread 07-06-2012, 08:12 AM   #7
stroker90
while cranking to start the jeep you should have the clutch pushed in so you shouldn't feel the jeep move when the clunk happens. my guess would be the crank position sensor has gone bad and that is why the jeep isn't getting spark
stroker90 is offline   Reply With Quote
Unread 07-06-2012, 09:43 AM   #8
thetbjeeper
Where is the crank position sensor and how can I check it I just assumed I didn't have spark because my cap and rotor and plugs are shot
Unread 07-09-2012, 07:56 AM   #9
Mishimoto
Check out this http://www.jeepforum.com/forum/f12/h...sensor-892548/ for diag on the sensor
Unread 07-09-2012, 10:32 AM   #10
thetbjeeper
I really appreciate the help my buddy took a look and turns out I broke a rod trying to clear water out of the block
Unread 07-09-2012, 12:14 PM   #11
Mishimoto
That would be a slight problem. Are you rebuilding or swapping the engine?
Unread 07-09-2012, 12:20 PM   #12
thetbjeeper
Swapping
