what would cause this noise?? - Page 2 - JeepForum.com
post #16 of 23 Old 11-20-2013, 05:19 AM Thread Starter
lsuguy4
I just thought bearings expand qhen they heat up and thats why the noose stops when its fully warmes up
lsuguy4 is offline
post #17 of 23 Old 11-20-2013, 06:07 AM
BIGBADWOLF
That is not what bearing or lifter noise sounds like. Check flex plate
BIGBADWOLF is offline
post #18 of 23 Old 11-20-2013, 06:54 AM Thread Starter
lsuguy4
Flex plate has been changed with a new one. Still same noise
lsuguy4 is offline
post #19 of 23 Old 11-20-2013, 06:55 AM Thread Starter
lsuguy4
No the flex plate has already been changed with a new one. A long with a new timing chain
lsuguy4 is offline
post #20 of 23 Old 11-20-2013, 10:07 AM
Evildriver-3
It could be a piston and when it warms up it gets better, thats what a loose piston would do
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #21 of 23 Old 11-20-2013, 10:33 AM Thread Starter
lsuguy4
Im going to buy a crank kit and replace it all feom the bottom end. And if that doesnt work I will save up and buy a new motor
lsuguy4 is offline
post #22 of 23 Old 11-20-2013, 10:37 AM
parker2849
Hi, new here but i just picked up a 2001 jeep tj sahara 4.0l. The mechanic i got it from says he just put a rebuilt engine in it because previous owner let an engine knock go till it stopped working. when he pulled the head off all he saw in one of the cylinders was a rod and wrist pin no piston. It was found in the oil pan. Dont know if that helps. Just letting you know about this experience.
parker2849 is offline
post #23 of 23 Old 11-20-2013, 10:59 AM Thread Starter
lsuguy4
I had the pan off a couple months ago and I seen all pistons in place with no play against the wall. No movement side to side or up in down. Checked everything I could. I even turned the engine to make each piston sit at the top and see the walls with a flash light and nothing. My guess would be main bearing or a collapsed lifter. Going to pull the vavle cover off this weekend and see what I find. When I put my hand on the oil pan when could I feel more vibration on the number piston vslrs others. That when I took all the pan in the first place. A few small metal shaving in the oil pan under the gunk oil. You could barely see them but you could feel them.
lsuguy4 is offline
