What? Why do I need a locker? I thought I had 4WD! - Page 5 - JeepForum.com
post #61 of 69 Old 12-04-2011, 09:48 AM
oneponycar
1979 FSJ Cherokee
I dumped the QT installed a twin stick NP 205 with indent removed so i now have a true 4 wheel drive. I welded the front spiders installed a locker rear end. On bad weather days I lock the front axle, Place the front axle in neural and rear in what ever the condition's call for. When 4 wheel drive is needed i just shift the front end in and away i go.
oneponycar is offline
post #62 of 69 Old 12-14-2011, 08:33 PM
Jrdchiropractic
2009 JK Wrangler
Originally Posted by pigphish
any tips for manual tranny's.
I tried doing this with my jeep when i was in some dirt with some spinning wheels but it was too easy to stall trying to negotiate all three peddles.
You will have to learn something called "heel-toe". An old- fashioned method of driving where you apply pressure to both the gas and brake at the same time (but with different pressure by rocking your foot left and right) with your right foot, freeing up your left foot for the clutch. Older cars from the 50's and 60's had a big long gas peddle (for the heel of your foot) and a wide brake (for your toe). In today's vehicles, you pretty much position the ball of your foot on both peddles. This is how you begin moving after stopped uphill, rather than the rev-like- hell method I see some dopey kids use. Hope that helps.
09 JK w/ a winch and duratracs
Just enough to get through most of the time,
get stuck sometimes, and still get home
Jrdchiropractic is offline
post #63 of 69 Old 01-10-2014, 05:35 AM
douglasbigland
My father was the one who taught me how to heel toe when I first started driving and it has stuck with me since; however, I was never able to do it same way he does (which I believe is the technique most people follow). The way that he taught me is what I believe to be the traditional way of heel toeing which is to pivot your foot over from the brake so that your foot is somewhat horizontal with the heelside of your foot controlling the throttle. I've always found this uncomfortable and have always used the outer edge of my foot to control the throttle.
douglasbigland is offline
post #64 of 69 Old 01-22-2014, 10:30 PM
Kudu
Forgive my ignorance, I have been reading and watching videos but when you go to a two piece front axle or have a posi lok and your front shaft always spins why/how is it spinning and not engaging 4WD? What is it in your TC that sends the torque to the front wheels when you pull the TC lever? Is it simply thrusting the spinning shaft forward to engage the axle shafts?
Kudu is offline
post #65 of 69 Old 04-21-2014, 01:59 PM
Nitr0EngiEx
very very nice explanation and write up thanks
Nitr0EngiEx is offline
post #66 of 69 Old 08-29-2014, 07:45 AM
turbogus
1978 CJ5
Thanks for posting, re posting and answering questions Jerry
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #67 of 69 Old 08-01-2015, 07:09 PM
FirstToy
1975 CJ5
Thanks for the extra effort and info. Being new to this game and working with an older jeep in trouble I need all the help I can get.
FirstToy is offline
post #68 of 69 Old 12-29-2015, 04:50 AM
willc86
does using the emergency brakes work for this?
willc86 is offline
post #69 of 69 Old 08-18-2016, 11:34 AM
TheJoe
New to this forum and just read this write up. Very informative and the best description I've read on lockers. Thanks.
TheJoe is offline
50-50 , 50/50 , differential , limited slip , locker , lockers , open case , open diff , open differnetial , torque delivery , torque split
Why do I need a locker? I thought I had 4X4! Jerry Bransford General Jeep & Off-Road Equipment 122 04-23-2017 01:07 PM
How to install a ‘lunchbox’ locker (ex locker, aussie locker, etc) in your D30 axle. CanukYJ Fabrication Shop 107 12-04-2011 07:14 PM
Front locker vs. rear locker airtraffic007 Engines & Drivetrain 16 04-09-2008 11:04 PM
fab thought? 360wrangler Fabrication Shop 0 07-09-2007 08:47 PM
has anybody thought of............... kaketj Fabrication Shop 15 03-10-2006 11:04 PM
