what trans to swap into tj - JeepForum.com
post #1 of 5 Old 04-29-2009, 01:23 PM Thread Starter
jmx663
im lookin to get a new transmission to swap into my jeep tj after i trashed the ax15. i plan on movin up to 37's shortly so i wanted to get something a little more heavy duty. its not a daily driver anymore so that opens up some options. any help would be appreciated
98 TJ Sport Long-armed, air-shocked blah blah blah
OFFICIAL Upper Tellico "Virtual Rally" Thread post #421
jmx663 is offline
post #2 of 5 Old 04-29-2009, 03:39 PM
H3RTCH
Live Free or Die.
H3RTCH's Avatar
I would go with the NV3550 out of a newer TJ which is basically bolt in, or an NV4500 out of a Chevy or Dodge pick up. More work, requires new bellhousing, and other stuff. Obviously more $$$, but at the very least go NV3550. Very solid transmission, and are decently inexpensive.
Brandon
2004 Jeep WJ Grand Cherokee Overland - My DD
1988 Jeep MJ Comanche 4.0L - Dad's
1999 Jeep WJ Grand Cherokee Limited 4.0L - Mom's
H3RTCH is offline
post #3 of 5 Old 04-29-2009, 05:37 PM Thread Starter
jmx663
appreciate the input... Anybody else???
jmx663 is offline
post #4 of 5 Old 04-29-2009, 08:32 PM
LJameson
AW4.
But I'm curious how you destroyed an AX15. With the right gearing (and with 4.88's you're spot on) it shouldn't be under any more stress.
1990 YJ
LJameson is offline
post #5 of 5 Old 04-30-2009, 03:34 AM Thread Starter
jmx663
just so happens that there came to be a little bit of water that somehow got into the trans. it took out all the syncros and ate a couple of gears
jmx663 is offline
YJ Trans swap, BA-10/5 to AX-15 ** Write Up Richmond88yj Engines & Drivetrain 105 12-27-2016 03:52 PM
cj7 trans swap earlb74 Engines & Drivetrain 3 07-09-2009 09:04 PM
Trans Swap Done....Still issues..help? Derka Engines & Drivetrain 2 03-24-2009 12:23 PM
auto trans swap HARLEYX2 Engines & Drivetrain 0 05-29-2006 07:00 PM
95 zj 5.2 engine and trans. swap into a 98 tj 98cheesetj Engines & Drivetrain 8 08-18-2004 08:05 PM
