What trans - JeepForum.com
post #1 of 4 Old 08-30-2013, 02:35 PM Thread Starter
FOURohXJ
1990 XJ Cherokee
What trans
Hi all I have a 1990 keep xj 5 speed and the time has came to replace my clutch, only problem is I have found 2 different clutch kits for it. One for the AX5 trans and one for the AX15 trans. Could anyone tell me what transmission I have. The build date is 12/89 if that helps and it's a 4.0l
Thanks
FOURohXJ is offline
post #2 of 4 Old 08-30-2013, 04:00 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Since you have the I6 you do not have the AX5, that was behind the 4cyl.
I use Luk 01901. Rock Auto has them for $143 ish +shipping.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #3 of 4 Old 08-30-2013, 09:25 PM
uberxj92
1992 XJ Cherokee
Some of older pre 91 xj's & mj's may have the ax5 Peugeot. I've seen a couple of 4.0's with weak Tranny.
Google AX5 vs AX15. Gives you good pics so you'll know
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #4 of 4 Old 09-02-2013, 10:28 AM
schitzangiggles
King of Macastan
The 6cylinders had the Pugot BA10-5 tranny and a/the giant turd. The AX is an Aisin (japaneese tranny not french) http://en.wikipedia.org/wiki/List_of..._transmissions and while not a bad transmission not found behind the 4.0 I6. Automatics ran the AW4 for the most part with the different models shown below.
Automatic transmissions http://en.wikipedia.org/wiki/Jeep_Ch..._transmissions
1984–1986: Chrysler A904 3-speed automatic, used with 2.5 L I4 and 2.8 L V6.
1987–2001: Aisin-Warner AW-4 4-speed automatic, used with 4.0 L I6.
1994–2000: Chrysler 30RH 3-speed automatic, used with 2.5 L I4.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
