What strength upgrades are available for 242 transfer case? - JeepForum.com
post #1 of 7 Old 11-25-2013, 03:46 PM Thread Starter
Charley3
I like the choices of selections it offers (2wd, 4 Full Time, 4 Part Time, 4 Lo). So I want to keep my 242, but I'd like to make it stronger, if possible.
Is it possible to put a strong chain on a 242 transfer case?
Other strength upgrades available?
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #2 of 7 Old 11-29-2013, 09:13 PM
draugauth
There are 3 versions of the 242. If you have the 4.0 then you probably have the NV242J
If you have the 4.7 then you should have the stronger NV242HD (has a thicker chain and gears, same planar gears as the J though)
Then there is the one from the H1 and HMV. It doesn't have the 2wd option but has 6 planar gears vs 3 and the thicker chain and gears.
I've heard they can be swapped around and that they can't. I need to do more research as I want the NV242SHD that people have built where they combined the one from the HMV and the one from the jeep to give all shift options and vastly improved strength.
draugauth is offline
post #3 of 7 Old 11-29-2013, 11:12 PM Thread Starter
Charley3
I have a 4.0 so I guess I have an NV242J. Can it be upgraded or would I need to replace it?
Does the NV242HD from the 4.7 have all the shift options?
Is there source that sells the NV242SHD ready made?
Charley3 is offline
post #4 of 7 Old 11-30-2013, 11:48 PM
draugauth
the only difference between the 2 nv242's use by Chrysler is the HD has the thicker chain and sprockets. aas for the modified hmv with the 2wd option, I don't know you'll gave to Google it.
post #5 of 7 Old 11-30-2013, 11:50 PM
draugauth
before I forget someone made a 4:1 low option but it weakened the casing to install it so production stopped a long time ago.
post #6 of 7 Old 12-01-2013, 12:23 AM Thread Starter
Charley3
I'm not a rockcrawler. I don't like 4:1 low.
I prefer 2.73:1 for Lo.
So I'm in luck.
Charley3 is offline
post #7 of 7 Old 12-01-2013, 12:24 AM Thread Starter
Charley3
Draguth, thanks for you excellent info.
Charley3 is offline
