What to Seal Carb Gaskets With? - JeepForum.com
post #1 of 3 Old 01-18-2005, 01:04 PM Thread Starter
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
I'm trying to find out why my 4.2L runs like poop after cruising on the highway (misfires at low RPMs) and alot of people are saying ignition module, but before I spend money on that I want to make sure my intake isn't leaking under the carb. It's pretty wet around there so I'm suspecting this may have something to do with it.
So what can I put on these gaskets to make they make a good seal to the manifold, carb, and adapters in between? I've got one vote for some copper spray stuff... any other opinions? I'm assuming RTV will be too thick, no?
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #2 of 3 Old 01-20-2005, 05:29 AM
75SV1
I use to use a gasket sealant that came in a spray can. It was red in color, the sealant. I realy liked it, but could be messy. I'd spray it on both sides and let it soak in. If I had to disassemble the parts later, the gakset would just peel off. Sorry cant remember what brand. I think it was in a blue can maybe like permatex.
Tom
75SV1 is offline
post #3 of 3 Old 01-21-2005, 05:08 AM
75SV1
I went to NAPA yesterday. They had some gasket stuff called Holomar or like that. I bought the tube of it. I used it years ago for some intake manifold gaskets on a 351W. The stuff isn't suppose to dry. I removed thats gaskets at a later date. They just peeled off.
Tom
75SV1 is offline
Rol Gaskets JeeperChampagne Engines & Drivetrain 3 09-05-2009 08:28 PM
Anyone use Lubelocker gaskets? Talos Engines & Drivetrain 15 09-24-2006 12:32 AM
Rocker Gaskets Rockiholic Cheap Tricks & Fixes 9 03-12-2006 07:00 PM
#$%@*&! header gaskets slickwillie Engines & Drivetrain 3 04-21-2005 12:09 AM
RTV sealant or Gaskets? fourlow General Jeep & Off-Road Equipment 2 05-07-2004 08:38 AM
