what to replace at 133 thousand miles - JeepForum.com
post #1 of 3 Old 09-01-2001, 11:06 PM Thread Starter
my litte red yj
i have a 1993 yj with a 2.5 i went to my local dealer and asked them when do i change my timing chain they said when it makes noise that made no sence then i said i head someone telling me that the oil pump's go and they make lower end noise they said no way the engine are known for lower end noise(sounds like a wrist pin when it get's hot) so who is right and at 130 thousand i have a exhaust leak between head and exhaust intake is this normal
my litte red yj is offline
post #2 of 3 Old 09-13-2001, 07:32 PM
GREGDOG95YJ
GREGDOG95YJ's Avatar
AS FOR THE NOISE I WOULD TAKE IT TO A MECHANIC AND LET THEM FIGURE IT OUT THE EXHAUST LEAK SHOULD BE FIXED BECAUSE THAT WILL CAUSE YOU TO LOSE POWER AND THE 2.5 DOESN'T HAVE MUCH TO LOSE. I WILL HAVE TO FIND MY OWNER'S MANUAL TO TELL YOU WHAT IS DUE FOR REPLACING AT 133,000 MILES A LITTLE LATER.
Jason Gregory
95 yj Rio Grande 2.5L
31" BFG MUDS, 1"BL,2" homemade spring lift, 150W KC'S, KN Filter, both air restricters gone, track bars gone, quick discos, & high flow cat
"just like all addicts my need to satisfy my addiction far exceeds my wallet!!"
GREGDOG95YJ is offline
post #3 of 3 Old 09-13-2001, 08:22 PM Thread Starter
my litte red yj
well i took my jeep to the dealer and the exhust manifold was loose and i asked them when to change the timing chain they said when it makes noise
How many miles does it take? Madmanmiller802 Tires & Wheels 4 09-18-2009 02:14 AM
Is ten thousand miles too late for a five tire rotation? spyderbyte Tires & Wheels 16 05-26-2008 06:24 PM
75k too many miles? Rock1127 Engines & Drivetrain 4 07-15-2005 11:50 AM
when is it too many miles? thenewkid General Jeep & Off-Road Equipment 7 10-11-2003 04:34 AM
How many miles on your 4.7L cherokeexj1994 Engines & Drivetrain 1 07-09-2002 08:08 AM
