what kind of oil to use in difs and trans - JeepForum.com
post #1 of 5 Old 07-11-2007, 06:22 PM Thread Starter
$300xjwith250k
it is a 94 xj stick stock difs and trans so what type of oil to use ??
$300xjwith250k is offline
post #2 of 5 Old 07-12-2007, 10:16 AM
Burbo
If you have open diffs then regular gear lube should be just fine for the axles. If you have limited slip then you will need to pick up lube that has the additives for limited slip. It should say on the bottle. As for the trans, if you pull the inspection plug you can check to see if it runs gear lube (brownish and thick) too or trans fluid (trans fluid should be red an thin). I believe that it runs trans fluid. Just pick up a couple of quarts of auto trans fluid and you should be fine.
I can never find time to do it right the first time, but I always find time to do it again!
Burbo is offline
post #3 of 5 Old 07-12-2007, 06:25 PM
cowpie01
2006 KJ Liberty
No owners manual? The diffs should use a 75w90 in both diffs unless towing then use a 75w110 or 75w140 in the rear. A good synthetic type gear oil will help. Reduced friction and will usually run up to 50F cooler more or less.
Changing out the diffs? Use www.lubelocker.com gaskets to make the job a more pleasant experience.
Environmentalist Green + Socialist Red = Facist Brown
cowpie01 is offline
post #4 of 5 Old 07-13-2007, 06:45 PM Thread Starter
$300xjwith250k
how much in the trans ?
post #5 of 5 Old 07-13-2007, 06:52 PM
curtjames37
curtjames37's Avatar
Will take about 4 quarts for drain and refill assuming you have an automatic. Use Dexron III only.
curtjames37 is offline
Chevy Trans, Is There A Seprerate Trans For Auto? DARRTILLM Engines & Drivetrain 0 07-15-2008 10:05 AM
What kind of wax are you using? Prot General Jeep & Off-Road Equipment 40 05-19-2008 03:10 PM
What Kind of wax? Mr. Joshua General Jeep & Off-Road Equipment 28 12-26-2005 10:25 PM
What kind? Fropleyqk General Jeep & Off-Road Equipment 5 08-21-2005 09:16 PM
What kind do I got? JSBlu974X4 General Jeep & Off-Road Equipment 3 05-08-2003 09:21 AM
