Fitted right up no problem, the heated water running in the intake is to replace the heat from the exh.manifold you no longer have with a installed header. I am in ohio and heated intake is needed in the winter. This helps the gas evaporate and stops the gas from pooling in the intake.
86 cj amc 304 bore 30 over, procomp cam, roller lifters, edelbrock intake and shorty headers, holley carb, hmi distrib, 2.5 procomp lift, 33x12.5x15 deep 10" mag, dana 30f, 44r, tf999 auto with lokar shifter, 300 transfer, 8000lb winch, procomp bumpers, body rusted and abused.
