What gears come stock i'n a yj? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > What gears come stock i'n a yj?
We now have Uniballs!The Original 3/8" Ruffstuff Diff Cover!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-21-2011, 12:12 PM   #1
Vin91
I have a 93 yj 4 banger 5spd what gears came stock, I was told 4.10 but I wasn't sure didn't know if anyone know or how I can tell which ones are i'n it?
Vin91 is offline   Reply With Quote Quick reply to this message
Unread 01-21-2011, 01:21 PM   #2
cj777
1977 CJ7
should be 4.10 http://www.jeepforum.com/forum/f12/y...-specs-563403/
Wanna cracker?
'74 CJ5
'81 CJ7
'03 TJ
cj777 is offline   Reply With Quote Quick reply to this message
Unread 01-28-2011, 12:20 PM   #3
BDH73
Yes I have a 94 YJ 2.5 5-speed, stock axles 4:10s,
BDH73 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2011, 01:27 AM   #4
VanDahmage
There should be a tag indicating the ratio on one of the lower left bolts on the dif cover. Mine was gone so since I had the whole assembly out we removed the cover and counted teeth. Gear - 43 / Pinion 14 = 3.071428xxxx So, ours is a 3.08 since that is one of three ratio's offered in the 89'YJ. Hope this helps someone...lil late on the date sorry..
VanDahmage is offline   Reply With Quote Quick reply to this message
