What gears come stock i'n a yj? - JeepForum.com
post #1 of 4 Old 01-21-2011, 12:12 PM Thread Starter
Vin91
I have a 93 yj 4 banger 5spd what gears came stock, I was told 4.10 but I wasn't sure didn't know if anyone know or how I can tell which ones are i'n it?
Vin91 is offline
post #2 of 4 Old 01-21-2011, 01:21 PM
cj777
1977 CJ7
should be 4.10 http://www.jeepforum.com/forum/f12/y...-specs-563403/
Wanna cracker?
'74 CJ5
'81 CJ7
'03 TJ
cj777 is offline
post #3 of 4 Old 01-28-2011, 12:20 PM
BDH73
Yes I have a 94 YJ 2.5 5-speed, stock axles 4:10s,
BDH73 is offline
post #4 of 4 Old 02-11-2011, 01:27 AM
VanDahmage
There should be a tag indicating the ratio on one of the lower left bolts on the dif cover. Mine was gone so since I had the whole assembly out we removed the cover and counted teeth. Gear - 43 / Pinion 14 = 3.071428xxxx So, ours is a 3.08 since that is one of three ratio's offered in the 89'YJ. Hope this helps someone...lil late on the date sorry..
VanDahmage is offline
Help with Locker on 8.8 and changing front stock tj gears to 4.88 j33p4l1fe4x4 Engines & Drivetrain 4 08-02-2010 08:14 AM
stock spider gears on my tj what should i change too? jeep_tech7 Engines & Drivetrain 2 07-20-2010 12:26 PM
What gears come stock in an 8.8? ElvisV04290 Engines & Drivetrain 4 07-17-2007 04:27 AM
Stock 97 TJ Sport gears IIIIIlllllIlI Engines & Drivetrain 6 06-11-2006 12:04 PM
how much to spend on stock gears Tri_X_Troll General Jeep & Off-Road Equipment 1 01-30-2006 11:07 AM
