What is this filter for and are there alternatives to this filter? - JeepForum.com
post #1 of 6 Old 07-03-2013, 12:06 PM Thread Starter
cj71985
I have a small filter sticking out of the top of my straight 6 engine. I thought maybe it was where a PVC valve or whatever it's call went. The one on mine looks burned out and just wondering if anyone new how important it is or what's it's job is.
cj71985 is offline
post #2 of 6 Old 07-03-2013, 12:12 PM Thread Starter
cj71985
Also here are some pics of the filter I'm talking about, you can see the end is cut out, I'm not sure if its like that for a reason or just burnt out because it was like this when I bout it a few years ago.
cj71985 is offline
post #3 of 6 Old 07-03-2013, 08:52 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Here you go;
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 6 Old 07-04-2013, 12:02 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
It was originally plumbed into the stock air filter. This would allow the carb to pull in any blowby and burn it. Most "performance" air filters have a connection under the base for the tube to connect to. Since yours is so small (not a good thing), there isn't room for one. I would suggest either a larger enclosed housing or a larger open one with the inlet. This will also help keep the engine from building up an oil film on it's surface.
I hope it doesn't get too cold in your neck of the woods, since your missing your choke.
jeepdaddy2000 is offline
post #5 of 6 Old 07-04-2013, 12:22 PM Thread Starter
cj71985
Yeah it's a pain to start in the winter with the cold and I'm planning on installing a choke kit this fall. Thanks a lot for the info guys.
cj71985 is offline
post #6 of 6 Old 07-09-2013, 04:51 AM
vadslram
It's the intake for the PCV (positive crankcase ventilation) valve. THe PCV pulls in air/fumes from the crankcase to keep unburned smoke and oil out of the atmosphere. That filter is there so that you don't pull a vacum inside the engine. Without the filter you will be sucking in dirt sand and dust directly into the valve train. If your PCV is working and you still have fumes coming OUT of that filter you are getting excessive ring blowby and it's time for a rebuild.
vadslram is offline
