what engine will work? - JeepForum.com
post #1 of 8 Old 07-22-2007, 08:30 AM Thread Starter
justdirtr/c
i have a 2000 xj with a 4.0, and the engine is bad with only 115k. my mechanic said that two of the lobes wore off the cam. my question is if i buy an used engine will any year work or do i need to buy the same year. thanks
justdirtr/c is offline
post #2 of 8 Old 07-22-2007, 12:09 PM
4.7stroker
Why not just have that one stripped, cleaned, inspected then have the parts needed replaced and put back together?
BTW read my links to preventing that from happening again.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 8 Old 07-22-2007, 01:30 PM Thread Starter
justdirtr/c
i was worried about all the metal from the cam going thru the rest of the engine and messing up bearings and all that in the bottom of the engine. the guy that it is working on it told me he drained the oil that it seemed to have a lot of oil in it.
i did read about how to prevent it from your links, but it was after it already happened. oh well i guess it won't happen again. thanks
post #4 of 8 Old 07-22-2007, 01:49 PM
RWB214
RWB214's Avatar
Something that came to mind when I read that part that the mech may have forgotten - the 4.0 uses 6+ quarts of oil, whereas the majority of engines out there use less than 5. Look at any coupon for an oil change, it usually says "up to 5 qt." I say 6+ for the 4.0 because if you run an oversize oil filter like many of us do it will hold between 6 and 7 qts to the top mark on the dipstick.
If you do need a new engine, I would focus on 2000 or 2001. The distributorless ignition system was introuduced in 2000 so prior engines may need some extra modification and/or a different PCM to be complatible.
RWB214 is offline
post #5 of 8 Old 07-22-2007, 02:19 PM Thread Starter
justdirtr/c
sorry that was a mis-print. my mechanic told me it seemed to have a lot of metal in the oil. sorry
post #6 of 8 Old 07-22-2007, 02:44 PM
4.7stroker
A good machine shop will hot tank the block and run brushes through all oil ways.
The block should be spotless when they are done.
It is safe to have it rebuilt.
Dwayne
[url]
[url]
post #7 of 8 Old 07-22-2007, 02:47 PM Thread Starter
justdirtr/c
yeah i'm thinking i will have it rebuilt. thanks for all the help.
post #8 of 8 Old 07-22-2007, 03:05 PM
4.7stroker
While they are in there have them bore it over .060 install a 4.2 crank n rods with the .060 4.0 pistons dynamicaly balance it and enjoy the extra power for very little extra cash. If you use the 4.2 serp balancer you don't need to have the crank snout machined either
Dwayne
[url]
[url]
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
97wrangler Automatic and 4 cylinder engine. THINKING ABOUT AN ENGINE SWAP AND MANUAL BoatsJeep Engines & Drivetrain 0 11-12-2009 07:01 PM
Anyone use an engine lift plate with a leveler to pull an engine? tankcj Engines & Drivetrain 2 08-06-2008 02:29 PM
Will this engine work timbow Engines & Drivetrain 2 11-07-2007 11:59 AM
Engine Work Near Birmingham bdub Engines & Drivetrain 3 10-02-2005 10:48 PM
