What do I need to make a 258 run? - JeepForum.com
post #1 of 6 Old 07-10-2010, 09:27 PM Thread Starter
MA88XJDude
Ok guys. Really basic question here. But if your in my boat its not so basic.
At bare minum what is needed electricaly for a 258 4.2L carburated jeep engine to run?
Will it need a CPS or TPS?? I mean obviously the coil, distributor, solenoid, alternator, batery. Im not talking about that stuff. I mean sensor wise or any other b.s.
Im going to be trying to get one to run so I just want to know in advance. It doesnt need any smog stuff anymore so I'd realy like to get rid of most that junk.
Thanks, Frank.
88' YJ/CJ Turbo Diesel
MA88XJDude is offline
post #2 of 6 Old 07-10-2010, 09:38 PM Thread Starter
MA88XJDude
I've been doing a little reasearch. I pretty much want to do what this guy wants to do:
Bare minimum wiring for a 258. - JeepsUnlimited.com Forums
Run no computer or anything like that. Just the carburated old school set up.
post #3 of 6 Old 07-11-2010, 06:36 AM
Happy Joe
Bare minimum; power the Ford ignition module correctly and verify that the associated wiring is in good condition.
If it has an electronic carb verify that it is clean, operational and properly adjusted.
Verify that it has good alternator to block, battery, chassis and body grounds.
Beyond minimum;
Forget HEI anything; if you want good ignition add a MSD-6a directly triggered from the stock autolite electronic distributor; add a junkyard Ford E-core ignition coil and good ignition wires and a brass terminaled distributor cap (you can use the high voltage cap, spacer and rotor from a Ford but don't accept anything but brass terminals in the cap). The MSD-6a will help the engine run with the poor mixtures generated by the carburettor and different length intake manifold runners.
Don't ghetto up the ignition do it once and do it right.
If you decide to bypass pollution devices (including the electronic carburettor and computer) be aware that you will be responsible for paying to make them operational again, and possibly subject to a large fine if the next owner decides to push the issue.
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline
post #4 of 6 Old 07-15-2010, 12:56 PM
1986cj
If you have a carbed engine you wont have or need a Throttle Position Sensor or a Crank Position Sensor, those would be for a fuel injection engine.
1986cj is offline
post #5 of 6 Old 07-15-2010, 01:52 PM
whiskeyNcoke
Do the "nutter bypass" Research it, and DO IT! I did it to mine, and it worked like a dream. I was able to eliminate all of my smog crap, and miles of wiring. It is very simple to do. If I get a chance I will copy and paste the diagram with instructions. I am sure it is on this forum somewhere though. Check in the CJ technical section.
That factory crap is just that, crap. I dont care how clean it is or if it works now or not. It will go out on you. I fought with my factory electronic carter carb and all the wiring, and it never worked right. Did the nutter bypass, and stuffed a rebuilt motorcraft 2100 on it, and it ran like a dream. Never had a problem again.
whiskeyNcoke is offline
post #6 of 6 Old 07-15-2010, 02:07 PM
whiskeyNcoke
Here you go. I found a really nice thread that goes over the process very well. It even has pictures.
http://www.jeepforum.com/forum/f8/ho...bypass-522262/
It will eliminate all headaches. If you lived anywhere near me, I would help you do it.
258 , 4.2 , 4.2 liter , 4.2l , electronics , i6 , wiring
Can i make this? placoo12 Fabrication Shop 4 02-03-2010 10:53 AM
who wants to make a speaker box lescobarz Audio, CB & Ham Radios, GPS, & Electrical 3 06-09-2009 09:40 PM
Does this make sense??? rpx13 Tires & Wheels 3 01-23-2007 01:09 PM
What should I make it out of? Scooter98xj Fabrication Shop 1 03-27-2006 07:49 PM
Do they make 'em? nbf6165 Tires & Wheels 2 01-31-2006 02:55 PM
