-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   What to clean inside of Transfer Case with? (http://www.jeepforum.com/forum/f19/what-clean-inside-transfer-case-1432919/)
Boss_hog 10-29-2012 08:18 PM
Ok so I hate asking nube questions like this, but I've search violated google and I am sick and dont feel like spending anymore time readin :thumbdown: I could not get a straight answer and I dont want to F*** up my TC.
I just cracked open my TC np231 and its dirty as hell. Now I am trying to figure out what to clean the inside with and the outside with. I want to paint the outside cause I got some left over engine paint and I want the inside spik and span for obviouse reasons.
From what I have people say clean it with brake cleaner/ carb cleaner/ purple power/ water and soap/ power washer. Wats everyones thoughts?????
Thanks in advance and sorry for the Nubby question (first time taking gears apart)
Pitbull330 10-29-2012 10:23 PM
Definitely brake parts cleaner. I use it every day. On engine overhauls. Transmissions. Rear differentials Ext... Brake clean dries almost instantly. Leaving no grease or grim behind.
jason m 10-29-2012 10:25 PM
Diesel fuel is what I use, works good. Cheaper than brake clean and wont really break down with oil/greese. So when your done seal it up in a old plastic bottle and use it again for the next cleaning job.
Jason.
Pitbull330 10-29-2012 10:28 PM
Jason.
No Diesel fuel, it leaves an oily residue.
jason m 10-30-2012 08:57 AM
Works fine for me for 20 years, so to each there own.
Jason.
Randonexplosion 10-30-2012 09:06 AM
I would say go with with Brake Clean. That's what I used when I did my SYE. And thats what I use when I crack open a diff.
Pitbull330 10-30-2012 09:59 AM
Jason.
Kerosene is better than Diesel fuel
Boss_hog 10-30-2012 11:52 AM
Thanks guys. I know everyone has their own preferences, but just didnt want to clean it with something thatll ruin the bearings n such. Brake cleaner is what I'll go with cause I have some on hand. Thanks again
rjbruzan 10-30-2012 12:35 PM
The nice thing about Brake Kleen is it leaves a dry and clean surface ready for RTV sealant.
jason m 10-30-2012 04:59 PM
True, just most folks don't have a kerosene at the pump like they do diesel.
I use the diesel for the heavy stuff then hit any surface that needs paint with brake clean, other than that fuel is what it gets.
Jason.
Kodiak17 10-30-2012 05:02 PM
Brake cleaner worked for me. Make sure when your washing the outside that you cover up the plugs and such so they don't get screwed up from soap and water.
james04si 10-30-2012 05:08 PM
I also use diesel in a parts washer. Cuts through grease and dirt quick. If I need to paint it I always use a wax and grease cleaner and put my gaskets on dry with no RTV and have never had a problem. I would use kerosene but like previously stated by someone else its not readily available at the pumps like diesel.
The time now is 11:37 AM.
