What Can I do for more POWER on my 4banger? - Page 2 - JeepForum.com
post #16 of 19 Old 05-04-2002, 09:46 AM
igofshn
Locked @ both ends
igofshn's Avatar
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by MusicMaverick:
<strong> </font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial"> No one makes a computer chip for YJ 2.5L's. </font><hr /></blockquote><font size="2" face="Verdana, Arial">Yes they do. Python makes the Venom 400 makes one. It runs around $350. An ignition kit would help a bit too. With all I mentioned, you'll be the peppiest lil' 4 banger on the block!</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">And what? You'll have a whopping 120 HP. Don't waste your money. A 4 banger is a 4 banger. It won't get any better. It will just lighten your wallet with all the wasted mods. Either sell it and get a 6 or put the money into effective mods for the trail. 4 bangers are great on the trail,just not on the highway.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #17 of 19 Old 05-04-2002, 11:18 PM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
Um.... Stock 2.5's made 90' and newer or 91' and newer (i forget which) come 120hp stock.....
And it CLAIMS to increase power as much as 25% through 1000-5000RPM range. How true it actually is I don't know. But the way I see it, it is a simple 4 wire connection. If I didnt feel any increase. I'd pull it out, put it back in the box, send it back and demand a refund.
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #18 of 19 Old 05-05-2002, 09:01 AM
gojurick
gojurick's Avatar
I'll let you know how the Python does. I'm putting one in along with a Borla header and exhaust, 4.0 throttle body and spacer. I'll test with the Python off and on and post the result. I've read both good and bad reviews of it, unfortunately the bad reviews seem to come from truck owners. We'll see, at least it's easy to remove.
'92 YJ, SOA w/ 35x12.5 X-terrains,RE quick-discs, Warn HS9500i, Detroit Electrac rear, ARB front, 4xDoctor rocker guards, AGR Steering, Borla Header & exhaust, Atlas II
Many bloody knuckles, Best of all, my wife luvs it too!!!
***Coming soon*** Chevy 350 V8 swap
gojurick is offline
post #19 of 19 Old 05-09-2002, 01:33 AM
I-4
I-4's Avatar
the regear is the way to go with larger tires...the whole thing about mechanical advantage.i plan on going straight to 5.89's when i do my soa.should work well with 35's...btw, i am keeping the 4 banger just to piss off the high horsepower crowd!
most of your power increase will come from opening up your intake.the exhaust will only work good with a lot of other pieces in place.a reworked computer also will work much better with a lot of other mods...a cam would help a lot.(be careful,it might not pass emmisions if you have to worry about that)i personally wouldn't waste my money on a computer upgrade.the thing the four cylinder has going for it is it small,light,and relatively torquey for its size.i saw a really interesting mod that could take advantage of that: a heavier flywheel.(tri-county gear's jeep for arca events.)that seems to me that a heavier flywheel would give you more bang for your buck.just food for thought... <img border="0" title="" alt="[Wink]" src="wink.gif" />
for the four cylinder sucks crowd...you can get close to 300 hp out of a four banger with the right mods!wouldn't be emissions legal,but...
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
only 4 quarts of oil for 97 4banger pete1182 Engines & Drivetrain 4 02-28-2007 10:11 PM
YJ 4banger to V8 swap mmasuperman12 Engines & Drivetrain 2 07-21-2006 03:57 PM
(amp output) RMS power vs. dynamic power orangez Audio, CB & Ham Radios, GPS, & Electrical 3 07-18-2005 07:21 PM
4banger to a 6 banger questions tatakai Engines & Drivetrain 26 07-13-2004 03:47 PM
33" tires powered by 4banger? TheGreenMachine Tires & Wheels 17 01-12-2003 09:43 PM
