what the best thing to boost HP? - JeepForum.com
post #1 of 18 Old 07-10-2005, 08:41 AM Thread Starter
Crown-N-Coke
what is the best thing u can do to a 4.0 engine to boost performance including horst power and torque. or boost gas milage... reg is $2.50 now... thanks
Crown-N-Coke is offline
post #2 of 18 Old 07-11-2005, 12:23 PM
denverd0n
The best thing to boost gas mileage is to drive in a conservative manner. There isn't anything you can do to the engine that will make even half as much difference to the gas mileage as what you do with your right foot.
denverd0n is offline
post #3 of 18 Old 07-16-2005, 10:58 AM
Linda or Greg
Linda or Greg's Avatar
Jeeps get crappy mileage. Can't do a thing about it.
'05 TJ High Country Daily Driver
Linda or Greg is offline
post #4 of 18 Old 07-16-2005, 06:05 PM
diesel158
you'd have to pick one over the other,performance or economy.
leave the gun,take the canoli's
diesel158 is offline
post #5 of 18 Old 07-16-2005, 07:00 PM
starheimberger
the best way to boost performance,buy a viper. the best way to boost m.p.g. buy a v.w. diesel.
1948 willys 4x4 project pickup
starheimberger is offline
post #6 of 18 Old 07-16-2005, 08:04 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
google for a 4.5 or 4.7 stroker. basically a 4.2 crank in a 4.0. not exactly bolt on but it is the best thing you can do and still have a 4.0 block
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #7 of 18 Old 07-16-2005, 09:47 PM
Traveller
A fifty horsepower dry nitrous shot usually adds what you need when you need it. Otherwise drive with a light foot, or get a bicycle.
Traveller is offline
post #8 of 18 Old 07-19-2005, 07:07 AM
600dollarXJ
From the research I've done on stroking the 4.0, several people have said that they get the same gas mileage even with an exta .7 liters and extra 50 hp.
I think changing the intake and exhaust to flow better and maybe getting some new spark plugs or wires or something along that lines would be good.
600dollarXJ is offline
post #9 of 18 Old 07-19-2005, 08:35 AM
diesel158
the thing about it though is to get somebody that's real experienced with it.you have to clearance the block for the longer stroke and it's real tight tolerances.But no doubt,stroking a motor is the way to go,they have stroker kits for 5.0 mustangs that punches them out to 347 cubes,that's a huge increase.I'm building a 355 for my Chevelle right now and if I would've had the dough I would've done a 383 stroker.
post #10 of 18 Old 07-25-2005, 11:40 PM
TXjeepTJ
TXjeepTJ's Avatar
air intake no doubt... keep it under 2500rpm use 5th gear as much as possible! haha
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #11 of 18 Old 08-01-2005, 03:08 PM
digibus
Fyi
As far as gas mileage, driving habits will help the most, but keeping your Jeep well maintained will help like new filters plugs and fluids and what not. You did not specify which 4.0 so if it has a distributor make sure you have a good set of wires too. A CAI will help a little and so will a free flowing exhaust but the MPG differences will be secondary to performance and it will all go back to how you drive her.
If you want to read up on stroker engine options for the 4.0 try here: http://www.jeep4.0performance.4mg.com/stroker.html
You will not have to change the quench height unless you go as far as the 4.9 or 5.0 stroker engine. You can build a 4.8L stroker with Chevy 350 pistons with the stock block. This is the route I have opted for. I have to have pros do all the machine work for me as I don't have the tools to do things like overboring the cylanders and regrounding the crank and such. So far all is going well and I have almost completed gathering all the parts that I will need.
If you want to find out more about Jeep performance another good forum is: http://www.jeepsunlimited.com/forums...splay.php?f=17
Good luck and have fun!
1999 4.0 WJ Limited NX Wet EFI Kit;HESCO Head, Cam and Water Pump;Apexi SAFC2;Accel 24lb injectors;K&N FIPK; 2.5" Dynomax Ultraflow SS Exhaust; Dynatech Cat; Banks SS header;Custom 3" Head Pipe;E Cut-out;62mm TB & Spacer; MSD DIS-4; Jet 180°stat;H&R springs;Eibach Sway Bars;Brembo Rotors; Streetscene grill;E.L. Dash ; Autometer C2 EGT, N2O & Fuel Pressure;Edlebrock A:F Meter
digibus is offline
post #12 of 18 Old 08-01-2005, 04:44 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
The only way to improve a Jeep's MP$ is to steal the gas.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #13 of 18 Old 08-02-2005, 12:53 AM
TJVigilante
I hear a stroker kit improves fuel economy by allowing you to keep it in a higher gear when cruising and accelerating. A hesco kit also is said to give you 225 whp and up to 280 lb-ft of torque, even more with a cam and performance head setup. There's also a turbocharger setup that's featured in the latest JP magazine that may suit your interests. If you stay in vacuum, you won't have any huge decrease in mileage, and a stroker kit will make that turbo give you all your power right at idle, which is what you need for wheeling. And it shouldn't be too bad at the stoplight against that lightning either.
TJVigilante is offline
post #14 of 18 Old 08-05-2005, 05:24 PM
digibus
Yeh so basically the best thing you can do for performance on the 4.0 is build a stroker. If you do don't waste money on a kit, do some research and build your own "kit". You will save yourself some cashfor other go-fast-goodies like nitrous or forced induction.
digibus is offline
post #15 of 18 Old 08-07-2005, 01:04 AM
gumcrew2
1991 XJ Cherokee
My 4.0L has a cold air intake, bored tb, spacer, headers, hi flow cat, super 40 muffler, and a 2.5" pipe. With that and no interior at all, removed for my bedliner. It's FAST, it's a 2 door btw. Night before last I raced a Ford F-150 5.4L V8 auto and we raced up to about 100 and I beat him by 3 or 4 car lengths. It's pretty fast, I can spin my tires while I get up to speed all the way to 60! If you do that, which I would highly recomend before any major work, you'll definently notice a nice increase. Other things that aren't very expensive to get more power would be using an intake manifold from a H.O. and getting it ported. That won't be very significant but every little bit helps and if you do it yourself with junkyard parts it'll be very cheap. You can build a stroker out of it in a weekend if you know what you're doing. All you need is a 258 crank and connecting rods. To make it actually work well you'll want a new cam and lifters and a valve cover spacer to prevent and contact. All that for a stroker will be under $500 with junkyard parts and a new cam and lifter setup. Beyond that there's always nitrous, but you'll need intake and exhaust work first. And forced induction which is expensive, unless you get a turbo from a junkyard and do some custom fab work!!!
"Nitrous? So is that like viagra for your Jeep?" -mom
"I flopped it"
gumcrew2 is offline
Sound boost karr2010 Audio, CB & Ham Radios, GPS, & Electrical 3 07-17-2009 08:17 AM
Budget Boost that thing! XJRidinHigh Tires & Wheels 2 05-06-2008 07:16 PM
Budget boost wj ctwistedpair General Jeep & Off-Road Equipment 2 05-20-2007 03:45 PM
Full Traction 2" boost lift or RE buget boost pete1182 Tires & Wheels 3 11-29-2006 07:19 PM
to add a budget boost; do you need anything else? King Tires & Wheels 5 10-20-2003 05:30 AM
