What axles and gear ratio? - JeepForum.com
post #1 of 8 Old 11-15-2012, 02:57 PM Thread Starter
KaileyA
Hey y'all, I was wondering what all needs to be upgraded and changed with my jeep when I lift it. It's a 2000 with 30 inch tires, a 4.0 manual, and stock axles and gear ratio. I'm looking to get a 4.5 lift soon with 35s. What axles and gear ratio should I get?
KaileyA is offline
post #2 of 8 Old 11-16-2012, 11:50 AM
BlueRubiconrich
min 4:10's keep the dana 30 front lose the dana 35 rear. Get a Dana 44 or Ford 8.8 rear
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 8 Old 11-17-2012, 12:20 PM
ltrail
1984 XJ Cherokee
what jeep? Depends on intended use. If it's half n half may not need to get all deep geared. If it's mostly trail toy I'd go deep in gears as the tires will only get larger from here. if you plan on polishing those axles and keeping them a while then I'd go 4.56. Should swap that rear though. If you have the lp front you may want to look into the hp 4cyl front axle. If one was lucky enough you may find a hp front with 4.10's and an 8.8 with same gears and an LSD?..
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #4 of 8 Old 11-17-2012, 01:29 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Also need to know your transmission type when recommending an axle ratio.
Wheelin98TJ is offline
post #5 of 8 Old 11-19-2012, 10:13 PM
Davetha
Davetha's Avatar
I would go with 4.88 on manual, and if you have a 3 speed auto go with 4.56.
Davetha is offline
post #6 of 8 Old 11-21-2012, 09:54 AM Thread Starter
KaileyA
It's a wrangler 5-speed manual transmission, and it's my daily driver. But I hit the mud a good bit.. Thanks for y'alls output. So what I've gotten from this is: if I get the 35s and the lift, I should swap the Dana 35 to a 44 and change the gear ratio to either 4.56 or 4.88?
KaileyA is offline
post #7 of 8 Old 11-21-2012, 08:15 PM
ltrail
1984 XJ Cherokee
Pretty much! havent geared enough d30's but i think that 4.88 is the max that will fit.
ltrail is offline
post #8 of 8 Old 11-21-2012, 08:37 PM
Jason
4.88, and yes, that's as deep as you can gear on the TJ D30.
Consider both steering and brake upgrades to go with those 35s.
Jason is offline
