What axel can i use in a 99 tj? - JeepForum.com
post #1 of 9 Old 09-07-2012, 09:54 PM Thread Starter
grabsomebuds
I Have a 99 tj wrangler and the rear differential went out. I heard its better to buy a used rear end but the local junk yard only has Cherokees. I am wondering what rear ends I can use in a 99 wrangler
Thanks
Kevin
grabsomebuds is offline
post #2 of 9 Old 09-08-2012, 07:40 AM
biffgnar
biffgnar's Avatar
You "can" use many different axles, although a lot of them require significant work. If you're actually asking what will bolt up easily, you need either an axle from another TJ/LJ or you need to buy a crate axle.
Romney in 2020!
biffgnar is offline
post #3 of 9 Old 09-08-2012, 05:06 PM
BlueRubiconrich
Or a TJ/TJL Rubicon Dana 44. or make work a Ford 8.8 or Dana 44
See JP mag
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #4 of 9 Old 09-09-2012, 02:53 AM
ltrail
1984 XJ Cherokee
Or if you happen to live close you can come get the one out of my yard!
Many will work, few will bolt in. Gear ratio needs to match front also.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #5 of 9 Old 09-10-2012, 07:02 AM Thread Starter
grabsomebuds
I live in Wilmington, NC. I checked the local junk yards and couldn't find a tj. If anyone knows a place in eastern NC I could go I would appreciate it
post #6 of 9 Old 09-10-2012, 08:53 AM
biffgnar
biffgnar's Avatar
TJs in JYs are a pretty rare find. Your best bet for used axles is forum classifieds and CL. Either that or you go to vendor. For you East Coast Gear Supply is close enough for you that you could physically pickup and save the shipping (which can be material). They are pretty well regarded around here.
Romney in 2020!
biffgnar is offline
post #7 of 9 Old 09-10-2012, 08:59 AM
Carlos14
As said above, craigslist is the place to be. Especially because everyone is getting rid of their stock d35 so you can pick one of those up dirt cheap.
Luck Favours The Prepared
Carlos14 is offline
post #8 of 9 Old 09-10-2012, 02:53 PM
tanksoldier
If you just want "an" axle, this is the way to go.
If you want an axle to build on (if you have or plan tires bigger than 33", etc, etc) the Dana 44 out of another TJ is your easiest, cheapest option.
Beyond that, a Ford 8.8 from ECGS is a good option... and it goes up from there.
If you're handy and have the tools (welder, etc) you can get a 44 or 8.8 from another vehicle and fab the mounts yourself. You'll want to make sure it's the 31 spline shafts, not 28 spline, and check the width.
Front and rear gears matching is something to check on all these options.
"I am a Soldier. I fight where I'm told and I win where I fight." GEN George S. Patton, Jr.
Army Jeep Club Bumper # C34
Colorado Jeep Club Member #1970
Originally Posted by Hussler View Post
Helen Keller on LSD could drive a submarine in space better than this kid could steer his own thread
tanksoldier is offline
post #9 of 9 Old 09-10-2012, 03:08 PM Thread Starter
grabsomebuds
I talked to the guy from ECGS today and it seems like the 8.8 works best for me since I don't do any serious off roading and custom fitting something myself isn't really an option. I appreciate the help from everyone
