what are the 5.2 engine differences? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > what are the 5.2 engine differences?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 03-31-2006, 08:26 PM   #1
sephirothq
Does anyone know the differences in the 5.2 from a 1995 1500 dodge ram and a 1996 Grand Cherokee.
does one make more power then the other?
sephirothq is offline   Reply With Quote
Unread 04-03-2006, 04:25 PM   #2
amctimmy
1973 FSJ Wagoneer
5.2 mopar
According to the people that I asked- the long blocks are the same.You may need to change intake,sensors,oil pan and pickup, exhaust manifolds.But the rest should be the same, including performance.
Tim
75 J-20
73Wagoneer
75AMC Gremlin X 401
66 A100 Dodge
amctimmy is offline   Reply With Quote
Unread 04-06-2006, 12:42 PM   #3
DaMadman
I was told tht the engin in the 1500 pickup makes more power.
That is also supposedly the case with the 5.7 engines in the 1500 and the Dakota
I know a guy that had the 5.7 Magnum in a Dakota and he said it didn't put out as much power as the 5.7 magnum in the 1500 full size truck
DaMadman is offline   Reply With Quote
Unread 04-06-2006, 12:55 PM   #4
strokinout
Don't you mean the 5.9's?
strokinout is offline   Reply With Quote
Unread 04-06-2006, 04:27 PM   #5
DaMadman
probably
