Welding Vs Spool... - JeepForum.com
post #1 of 11 Old 02-03-2014, 02:28 PM Thread Starter
Rockdrummer93
Welding Vs Spool...
Ok so Im starting to order parts for my HP44. Im going to permanently lock it since I'll have the locking hubs. My question is since I'll have to buy a new carrier to run 4.88s would it be better to just buy a new carrier and weld my gears or just to buy a spool and call it a day. I'm trying to do this the cheapest way possible but don't mind spending a little extra if it is really all that worth it. Let me know what y'all think.
2014 Cherokee Of The YEAR
Rockdrummer93 is offline
post #2 of 11 Old 02-03-2014, 02:30 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Buy a mini spool. That way you can remove it if you don't like it.
Luck Favours The Prepared
Anticanman is offline
post #3 of 11 Old 02-03-2014, 02:33 PM Thread Starter
Rockdrummer93
Well a mini spool kind of defeats the whole issue.. Cause i'll still need a new carrier and if i buy a new carrier i'll just weld the spiders.
post #4 of 11 Old 02-03-2014, 02:34 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I just did one this weekend. Shoulda bought the mini spool. He hated it
post #5 of 11 Old 02-03-2014, 02:36 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You'll set up gears once and if you want the spiders back in for any reason you can choose that option. I understand you can unlock the hubs and it'll be open but the mini will be a lot stronger.
post #6 of 11 Old 02-03-2014, 02:38 PM Thread Starter
Rockdrummer93
I understand that. I really don't care about taking it back out. Thing is at the price of a new carrier and mini spool i can just buy a full spool.
post #7 of 11 Old 02-03-2014, 02:47 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Full spool is going to be stronger. Go with that.
post #8 of 11 Old 02-04-2014, 04:37 AM
Evildriver-3
Get the spool
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #9 of 11 Old 02-04-2014, 03:23 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You don't care now, but if you don't like it or the LL causes the vehicle to be unsellable, your out a lot of extra money.
Mini spools are plenty strong, especially in a 35. They are cheap and easy to remove. If your dead set on a cheap lock up in the front i believe you will be money ahead going this route.
jeepdaddy2000 is offline
post #10 of 11 Old 02-04-2014, 04:47 PM
jason m
Nothing but the facts
jason m's Avatar
Im welded front and rear on 60's both steering. With that said I like the weld but I knew what and how it would handle in my rig as I drove a buddys rig with the same package.
You do get alot of plow steer and it does make the power steering run hotter, so add a cooler and expect to make more turns to get around.
But going back to the topic weld VS spool, well a mini spool is pretty cheap but if you have a welder thats cheaper.
If you do weld it just weld the spiders to the side gears, this way if your not happy with it you can cut them out and place another set in, it will suck but can be done, yes I have done that
If you decide you like the welded carrier, then do like I do and add some extra steel to connect the two side gears together, turn that carrier into a nugget of iron and it will last for years.
Oh and phase your U-joints, you got to remember you made a drive shaft out of those two axle shafts, regardless if you have locking hubs or not, those will only unlock the wheel hub but the driver and pass shafts are in one plane/phase.
So if the two sides are not in phase then they bind, its like night and day if you dont phase them, trust me I found that out the hard way to.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #11 of 11 Old 02-04-2014, 05:45 PM Thread Starter
Rockdrummer93
Originally Posted by jason m
Im welded front and rear on 60's both steering. With that said I like the weld but I knew what and how it would handle in my rig as I drove a buddys rig with the same package. You do get alot of plow steer and it does make the power steering run hotter, so add a cooler and expect to make more turns to get around. But going back to the topic weld VS spool, well a mini spool is pretty cheap but if you have a welder thats cheaper. If you do weld it just weld the spiders to the side gears, this way if your not happy with it you can cut them out and place another set in, it will suck but can be done, yes I have done that If you decide you like the welded carrier, then do like I do and add some extra steel to connect the two side gears together, turn that carrier into a nugget of iron and it will last for years. Oh and phase your U-joints, you got to remember you made a drive shaft out of those two axle shafts, regardless if you have locking hubs or not, those will only unlock the wheel hub but the driver and pass shafts are in one plane/phase. So if the two sides are not in phase then they bind, its like night and day if you dont phase them, trust me I found that out the hard way to. Jason.
Thanks Jason that's the kind of advice I would looking for!!
