weird vibration through out the jeep - Page 2 - JeepForum.com
post #16 of 22 Old 10-30-2013, 12:54 AM
JohnCrabtree
1994 ZJ
Originally Posted by wildkardboyz View Post
Yea but now the dam nuts for the tranny mount or aka skid plate broke loose on the weld on the driverside as well today I know this is a common problem but know one talks about how to fix it
JB Weld, Duct Tape, and Industrial Zip Ties. Throw some rattlecan PlastiDip on top of it and you'll be set to go to the indy 500.
JohnCrabtree is offline
post #17 of 22 Old 10-30-2013, 05:10 AM Thread Starter
wildkardboyz
Well I know your trying to be funny but please be an adult and listen to your mom. If have nothing good to say dont say it at all. Im broke down have promised my 2 boys we would wheel this weekend. So im asking for advise.
Pain... is .... weakness... leaving the body....
wildkardboyz is offline
post #18 of 22 Old 10-30-2013, 05:48 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Someone will chime in.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #19 of 22 Old 10-30-2013, 12:45 PM
JohnCrabtree
1994 ZJ
Be an adult and listen to my mom? Alrighty then.
Here is my advice, completely serious, Never promise to go wheeling when you own a jeep.
post #20 of 22 Old 10-30-2013, 03:14 PM Thread Starter
wildkardboyz
I'm starting to learn that very quickly
post #21 of 22 Old 10-31-2013, 11:45 PM
Evildriver-3
Put up some pics so i can see these broken welds. The shaft you'll need to see your local driveline shop and have it re-tubed... or leave it out if you don't have AWD and put it in when you get to the trail.
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #22 of 22 Old 11-01-2013, 03:48 PM Thread Starter
wildkardboyz
The nut welds in the frame that hold the nuts fast. it seems to be a very common thing were there is salt. So what I did was cut a 1/4 inch plate 2 inches wide tapped the 1/2 hole then welded the 1/2 x 13 nut on to it. I also tapped the old holes on the frame so the bolt would go in the frame. Then I welded the 2 inch plate to the frame. And bolted the skid plate back up to that. I also added two drain holes 1/2 in the front of the skid plate and behind it. To solve the issue from happening again.
