weird vibration through out the jeep - JeepForum.com
post #1 of 22 Old 10-28-2013, 02:32 PM Thread Starter
wildkardboyz
Ok so I have a vibration in between 45 60 I was told lower control arms. So I replaced everything drag links upper control arm bushing trac bushings new lower control arms and a lift while I was add it. After everything it still vibrates at 50 now. But none the less its still there. Today I engaged the 4x4 on the highway and the vibration stopped. But as soon as I left of the gas it starts again. Can someone help me out. What the hell is going on. Thanks in advance.
Pain... is .... weakness... leaving the body....
wildkardboyz is offline
post #2 of 22 Old 10-28-2013, 02:42 PM
biffgnar
biffgnar's Avatar
First, don't put the jeep in four wheel drive on high traction surfaces. Second, pull each drive shaft individually and drive without it. If it goes away with one of them out then that is your source - bad angles, bad ujoints, bad CV joint, etc.
Romney in 2020!
biffgnar is offline
post #3 of 22 Old 10-28-2013, 03:32 PM Thread Starter
wildkardboyz
I know its bad to do that on drive surfaces but its the only way to check it I guess. Can the weight or balanced be lost on the drive line or can the pinion be causing this problen as well
post #4 of 22 Old 10-28-2013, 07:19 PM
uberxj92
1992 XJ Cherokee
Yes. And like biffgnar said try one drive shaft at a time.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #5 of 22 Old 10-28-2013, 08:18 PM Thread Starter
wildkardboyz
I found the transmission mount loose and the transmission mived alot when I shook it. Could that be a problem?
post #6 of 22 Old 10-28-2013, 10:28 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Possibly. How loose is it?
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #7 of 22 Old 10-29-2013, 07:13 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yes. Always fix known issues before getting on another rabbit trail.
What do your engine mounts look like?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #8 of 22 Old 10-29-2013, 07:20 AM Thread Starter
wildkardboyz
They seem fine but im gonna check those today. I bought this jeep a month ago. And oh man its been interesting
post #9 of 22 Old 10-29-2013, 07:36 AM
0125JeepGuy
your transfer case bearing(s) could be shot. try moving the yokes, there should be little to no play in it. also check your U Joints for sure
0125JeepGuy is offline
post #10 of 22 Old 10-29-2013, 07:52 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Have you checked the fluid level/condition of both diffs, trans, and transfer case?
post #11 of 22 Old 10-29-2013, 03:19 PM Thread Starter
wildkardboyz
Think I found the problem the front drive shaft is bent
post #12 of 22 Old 10-29-2013, 04:18 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Think 8 found the problem the front drive shaft is bent
Who is 8 and how did he find the bent driveshaft?
post #13 of 22 Old 10-29-2013, 05:17 PM Thread Starter
wildkardboyz
I lifted up the front axle and spun the tire noticed the driveline moving way out of wack seems to be bent by a rock or something
post #14 of 22 Old 10-29-2013, 08:30 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Good for you!! You found an issue using good old noggin pokin'. Beats the keyboard and monitor doesn't it?
post #15 of 22 Old 10-29-2013, 08:43 PM Thread Starter
wildkardboyz
Yea but now the dam nuts for the tranny mount or aka skid plate broke loose on the weld on the driverside as well today I know this is a common problem but know one talks about how to fix it
