Weird Problem - JeepForum.com
post #1 of 7 Old 03-17-2013, 01:12 PM Thread Starter
SuperStew11
Weird Problem
I'm out in my 2000 Grand Cherokee, I start it and notice my Engine light is on (thinking great now what? I guess ill just take it home) I put it into Drive and it slams into gear like the rpm were high but I was just idling, go to drive and and it has no power like its in a high gear. I get it home and check the code. I get the 0320 and 0700 codes which is crankshaft sensor and transmission communication, I try turning it over it and takes three tries before it refires. After that it now seems to run fine, the engine light turned off after a day but I'm still getting the 0320 and 0700 code.
Any help or ideas would be greatly appreciated
SuperStew11 is offline
post #2 of 7 Old 03-17-2013, 01:17 PM
Tjdude08
Can't help as to what the problem is but until you clear the codes you will continue to see those codes.
Tjdude08 is offline
post #3 of 7 Old 03-17-2013, 01:22 PM Thread Starter
SuperStew11
Is there a way to clear the codes without having a code scanner?
post #4 of 7 Old 03-17-2013, 01:49 PM
Tjdude08
Any car parts store should be able to. I've had similar problems with my jeep. Cel light came on. Spit codes out then next day dissapeared. Codes didn't but I cleared them
Tjdude08 is offline
post #5 of 7 Old 03-17-2013, 02:16 PM Thread Starter
SuperStew11
Alright will do and see what if anything happens, thanks for the help
post #6 of 7 Old 03-29-2013, 11:14 AM Thread Starter
SuperStew11
So it's happened again, went to start it and wouldn't fire just kept cranking, took 6-8 tries and finally fired up. Driving was like it had no guys and found out once it gets to 100Kph, it starts lurching so had to slow down a bit. Could feel the engine as I drove gain and lose power. Does this sound like the Crankshaft sensor dying? Any ideas or help would be great Thanks
post #7 of 7 Old 04-11-2013, 02:12 PM Thread Starter
SuperStew11
So time for a update, so I put new fog lights on my WJ last week and the other day coming home midnights I forgot to turn them off. I ended up killing the battery completely, so I jumped it and back to work that night I went. After work go to start it and nothing just keeps cranking over and over. So I decide the CPS has finally bit the bullet, I replaced it yesterday and tried starting it again. Guess what? it just kept on cranking over and not firing. After a little research turns out the WJs like to completely forget how to start when the battery dies. All I had to do was put the pedal to the floor, crank it over and it fired right up, and just had to hold it at a high rev for a minute or so until it could idle on its own.
So now I play the waiting game and see if the new CPS is working fine and that my battery is still healthy enough to keep going
