Weird Gear Pattern - JeepForum.com
post #1 of 4 Old 05-02-2012, 05:03 PM Thread Starter
StrokedWJ
StrokedWJ's Avatar
Weird Gear Pattern
I can't figure out what would be causing this weird pattern I'm getting while trying to setup my Ford 9. I'm a novice when it comes to gear setup, but I have a general idea of whats going on, and the patience/time to make sure everything is perfect before putting it into the jeep. I can't get the contact pattern on the coast side off of the toe regardless of the amount of pinion shim. I checked runout on the backside of the ring gear and get .001-.002. I checked backlash at several places around the gear and get .007 to .010. I have noticed that in order to pull the pinion support, I have to loosen the side adjusters. I did not have to do that with the old gearset. The pinion & support would pull out without needing to loosen the side adjusters. Here's what the pattern looks like.
Drive:
Coast:
Thanks
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #2 of 4 Old 05-02-2012, 11:16 PM
jnicewan
I was kind of thinking you have the pinion too far back from the ring gear, have you tried to bring the pinion closer to the ring gear as all? That is a weird pattern though. Anyway here is a pretty useful link for that may help you out. It seems like one of the example pics on the link for "pinion is too far away" is similar to what you have.
LINK
jnicewan is offline
post #3 of 4 Old 05-03-2012, 10:13 AM Thread Starter
StrokedWJ
StrokedWJ's Avatar
Yeah, I found a similar picture on the Richmond Gear instructions while searching last night. I ordered a new shim pack and will play around with it some more this weekend to see if can't improve the pattern. I'm also wondering about the changing backlash that I'm noticing around the ring gear. It varies about .004", but I don't see any runout on the backside of the gear. Could that mean my pinion bearing cups aren't 100% seated so the pinion is slightly crooked?
post #4 of 4 Old 05-05-2012, 06:35 PM Thread Starter
StrokedWJ
StrokedWJ's Avatar
I was able to improve the pattern some and at least get the coast pattern to stop running off the side of the tooth. Think I'm gonna run it like this. Also opened up the backlash a little to 10 thou.
gear pattern check jose_p_adams Engines & Drivetrain 2 03-21-2011 09:20 PM
Gear Pattern Help Rob91 Engines & Drivetrain 6 01-09-2011 11:17 PM
D44a Gear pattern help - calling all gear install experts BLACKzj52 Engines & Drivetrain 38 06-21-2010 06:37 PM
HP30 Gear pattern help - calling all gear install experts BLACKzj52 Engines & Drivetrain 10 06-13-2010 09:01 PM
How does this gear pattern look to you? redhatman Engines & Drivetrain 1 05-16-2010 04:15 AM
