weber choke ? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > weber choke ?
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 02-26-2003, 08:03 AM   #1
bodi
weber choke ?
It seems that in the past couple of days my weber choke doesn't work. it takes a few seconds for the jeep to start and then it idles really rough until it gets warm. how do i check to see if the choke is stuck and what should i do?
...so much to learn...so little free time.
83 CJ7 w/remanufactured jasper 258 I6 w/t-5, Weber carb, new exhaust, PS, PB, 2 1/2" Lift, 31" BFG's, herculined interior and s**t brown paint job (for now) "in to deep..but thats when it starts getting fun"
Brown Jeep Club Member #2
bodi is offline   Reply With Quote Quick reply to this message
Unread 03-01-2003, 03:48 PM   #2
CJRUSTY
I found that if you step on the gas pedal while starting the engine the vac. pulloff will pull the choke open enough to drop the choke linkage off of the high idle cam .Try starting the engine by stepping on the gas once to set the choke then crank the engine untill it starts. This works with mine a lot better.
CJRUSTY is offline   Reply With Quote Quick reply to this message
