Weber 32/36 WONT IDLE!HELP!! - JeepForum.com
post #1 of 4 Old 07-10-2015, 02:33 PM Thread Starter
dinolambchop
I purchased this weber brand new, the entire kit because all my research and forums I read made me believe that it would be the best. Well this thing isn't doing me good at all. The jeep will start and idle while sitting(I always let it warm up). It even drives down the road just fine! BUT once I want to come to a stop or push in the clutch at all for neutral the jeep instantly wants to stall out! I have a holley fuel pressure reg. on it as directed.
Someone please give me and explanation!!
dinolambchop is offline
post #2 of 4 Old 07-11-2015, 01:30 PM
BlueRubiconrich
try turning in the screw in the back/side to idle it up.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 4 Old 07-13-2015, 12:02 PM Thread Starter
dinolambchop
Ive done that, it does kick the idle up (higher than it needs to even be)..but doesn't solve the problem of it dying when I try to stop or push in the clutch
-85'cj7
-86'cj7
-87'yj
-97'tj
post #4 of 4 Old 07-13-2015, 06:06 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
How much fuel pressure are you running?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
